Wheel rubbing on lower control arm? Please Help!
Old Jun 16, 2006 | 07:08 PM
2001RedDodgeRam's Avatar
2001RedDodgeRam
Default Wheel rubbing on lower control arm? Please Help!
When I take a left curve at speeds around 60 I get a serious viberation on the front drivers side.
I took the wheel off and noticed that the lower control arm was rubbing on the tire. (the other side was fine)
What would cause my tire to rub only on the drivers side control arm?
How do I fix this?
Any help is greatly appreciated.
Old Jun 16, 2006 | 07:26 PM
GOD RAM IT's Avatar
GOD RAM IT
Default RE: Wheel rubbing on lower control arm? Please Help!
do you have a wider than stock tire on stock rims? if so than thats your issue.
either that or your trac bar is shot allowing your axle to move side to side.
Old Jun 16, 2006 | 07:30 PM
The Burning Rom's Avatar
The Burning Rom
I agree ^^^^^
Old Jun 16, 2006 | 07:37 PM
2001RedDodgeRam
Thanks for the reply.
The tires are a little bit bigger then stock which raised the truck up some. I have around 30k miles on those tires and have had no issues so I doubt it is the tires.
Also the tires are just barely bigger then stock, nothing crazy
Old Jun 16, 2006 | 08:07 PM
2001RedDodgeRam
Why does it happen only on that one drivers side and not the passangers?
Could it be the shock is shot?
Old Jun 16, 2006 | 08:16 PM
habeba86's Avatar
habeba86
He shouldnt have the wheel turned enough to rub the control arm going 60....that jst doesnt seem rite.
Old Jun 16, 2006 | 11:19 PM
Chopper1's Avatar
Chopper1
I agree. There is no way you will turn sharp enough at 60. There must be something loose or seriously worn out. I would check the entire left side suspension. At 60MPH is not the time to discover what broke loose.
Lug nuts tight, Wheel bearing, Ball joints. These are the ones that would let the wheel tilt.
Shock, upper shock bracket and lower bolt, Track bar, tie rod. Could cause the vibration.
Serious alignmment issue.
Old Jun 17, 2006 | 12:24 AM
shott8283's Avatar
shott8283
does your truck wander really bad? i would think it could be a SEVERELY worn t-bar
agree with above posted...check everything,,, balljoints,...hubs... etcetcetc
Old Jun 17, 2006 | 01:09 AM
GOD RAM IT's Avatar
GOD RAM IT
wow, I totally missed the 60 mph thing. You have a serious issue my friend.
the other thing is that if his steering box wasnt exactly centered than he could steer farther in one direction than the other. But at 60mph you would be flipping your truck
Old Jun 17, 2006 | 01:12 AM
shott8283's Avatar
shott8283
woh... same here... missed that 60 thing... your tires are really gonna have to be way off center to be able to rub and a turn radius of 60 mph...
do you have the stock Tbar? if you have an aftermarket T-bar with hiem joints it could have come off center.. just another possiblity
