tonno cover
Old Jun 29, 2006 | 04:32 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default tonno cover
I want to install one but i have a drop in bed liner, will i need to remove the bedliner or just cut pices out so it will fit.
http://www.4wheelonline.com/Products...roductId=62241
that is the one that i am looking at. And after i do put it in how much gas will it save?
Old Jun 29, 2006 | 10:24 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Default RE: tonno cover
Is your bed liner an over rail or under rail bed liner? I have an under rail bed liner with an Extang tonno and there were no modifications needed. It gained me about 1~2 mpg on the highway after I installed it.
Old Jun 29, 2006 | 12:42 PM
mavrik's Avatar
mavrik
do yourself a favor and look into the tri-fold tonneaus from lund and extang..i have had a ton of them and will never go back to a standard tonneau since i got my tri-fold from lund....if the bedliner is over the rail then cut the rails off....
Old Jun 29, 2006 | 03:10 PM
crazy1snow's Avatar
crazy1snow
can you lock any of those tri folds? i mean so that the whole thing is folded out and locked down including the tailgate? that's been my issue with them is that i can't lock it up.
anybody have a spray in liner that they sprayed the rails with too? and using a tonneau? or am i pretty much SOL?
Old Jun 29, 2006 | 05:57 PM
Zeppelinrocks
im just goimg to take the bedliner out and store it until i need it and i can always throw it in, but the tri folds do look like they are a better quality.
Old Jun 30, 2006 | 03:24 PM
1500sport's Avatar
1500sport
I highly recommend a sportmaster tonneau cover. In my family alone we have 5 of the slant side sportmasters and love them to death. They are easily the use, the snaps are metal and have set screws in them so they don't move at all when the cover is off and you don't have to screw around with aligning each snap up when you put the cover back on. I've looked at the extang's and the snaps don't impress me at all. Just my opinion though.
http://www.sportmasters.com/tonneau.htm#slant
If you have an under the rail bedliner, removal is not necessary. If it does go over the bed at the front of the truck just cut that part off and screw the bedliner to the front of the bed. If you have a spray on bed that happens to go over the rails you should not have an issue either because it is bonded to the truck. The tonneau covers have self ahesive tape on the bottom of the rails the compress for a tight fit.
Old Jun 30, 2006 | 05:57 PM
Chopper1's Avatar
Chopper1
ORIGINAL: 1500sport
I would agree with the entire recommendation. I also had the Sportmaster cover on my last truck and was great. If you need to put stuff in the truck, just roll it to the front, snap in place with the straps, and roll on. The one I had was already on the truck when I got it. Three years later I broke a corner piece. Called them and they shipped me a new one. No charge, no questions.
Old Jul 1, 2006 | 05:23 PM
Zeppelinrocks
how much would one of the sportsmasters cost?
Old Jul 7, 2006 | 03:39 PM
1500sport's Avatar
1500sport
ORIGINAL: Zeppelinrocks
Depending on where you go and which style, my slant side snap style cover was $220 but it took a while to find it that cheap. I would guess you should be able to easily get one for $250 or less.
