Cutting 2500 Rotors/hub bearing
For those on here that have 2500 Rams in which the rotors and hub bearings are pressed together with the lugs, I talked to my local NAPA yesterday and they said they can turn the rotors with the hub bearing attached. Haven't tried it yet but if they can, it will save a lot of work and perhaps the rotor or bearing. Burning Rom, I got the GM rear brake cylinders and the counterman at NAPA has heard about the use of the larger cylinder on Rams. He new nothing about the BPV but said guys are happy with the GM brake cylinder.
