Corrosion on Battery Terminal
Old Jul 7, 2006 | 09:10 PM
Sehr916's Avatar
Sehr916
Default Corrosion on Battery Terminal
Anybody know what causes this? I never had a problem with this until the first time I removed the negative battery cable a few months ago. Now The negative post and clamp start to corrode the green/white color. I cleaned it the last time I removed it and it did it again and I am sure that its tight. Should I get some of that gel they have for 99 cents at a parts store? Thanks for any help
Old Jul 7, 2006 | 09:20 PM
fiveliterbtr's Avatar
fiveliterbtr
Default RE: Corrosion on Battery Terminal
White lithium grease is what I use Works like a charm...I've used that red battery spray before...until I did it on a Ranger one evening...the truck stayed in the shop overnight waiting for some parts, and by morning, it showed a little corrosion already.
I believe it has to do with a natural reaction between the lead, the air we breathe, and the release of gasses from the battery...for whatever reason, Chrysler corp. vehicles are the worst, by far.
Old Jul 7, 2006 | 09:23 PM
Sehr916's Avatar
Sehr916
I got some spray lithium, So ill go clean it off and spray some on and let ya know how it works. Thanks!
Old Jul 18, 2006 | 02:01 AM
fiveliterbtr
So, how's that corrosion doing? [sm=feedback.gif]
[sm=happybounce.gif]
