hot air
Old Jul 9, 2006 | 11:51 PM
quadro's Avatar
quadro
Default hot air
Hey guys. I've had a question for a while that I was just reminded of today. When I 'm cruising at about 50-55 and I start going up a hill, I noticed that it felt like the heat was on. There seems to be quite a bit of hot air coming from the ducts. I didn't know if this could be a normal thing or not. It dosen't sound like it but I'm not too familiar with that system
Old Jul 10, 2006 | 02:31 AM
Sehr916's Avatar
Sehr916
Default RE: hot air
I dont know if this relates at all but I have heard of a vaccumm leak causing the air to switch to the defrost vents when at WOT.
Old Jul 10, 2006 | 03:09 PM
crazy1snow's Avatar
crazy1snow
Default RE: hot air
agreeing with sehr on that one. heard that as a problem because of a vaccum leak somewhere near the ac i think... i don't remember for sure.
Old Jul 11, 2006 | 12:24 AM
quadro's Avatar
quadro
Default RE: hot air
does anyone know of a way to find the leak
Old Jul 11, 2006 | 11:30 AM
wildwolf59's Avatar
wildwolf59
Default RE: hot air
most likely a leak.......just have to look at all your lines and check them or i think someone said maybe a check valve in the line could be bad....mine has been doing it for a long time now and i havent fixed it yet!!!!! just one of those things i can live with for now until later then i will find it!!!!!
Old Jul 11, 2006 | 01:44 PM
HankL's Avatar
HankL
Default RE: hot air
This may be the 'wild vents' problem discussed in the old post below or it might also be a vacuum leak in the hoses to the cruise control solenoid that is over near (and below) the battery mount.
I had ordered a replacement part from Dodge that is supposed to correct the
'Wild Vents' problem. This is where AC/Heat air blowing out vents
mysteriously changes and comes out other vents. It is most prone to happen
when accelerating. I read that the cruise control can suddenly 'pop out' of
setting too.
I haven't had the vents change wildly like that myself, but I have had the
'Defrost' setting refuse to work, then come on suddenly 10-15 minutes later.
Chrysler's 'Fix' is replacement part number 04677204.
I think there is a TSB on this.
I had seen the description of the problem in some automotive service
magazines.
My local Dodge dealer told me they now had the part, and I went and picked it
up (plus a broken passenger side sun visor clip). Cost was $7.84
The replacement part turns out to be about the size of a 35 mm Film can and is
a small vacuum reservoir with a built in check valve.
The original part (4306923) was a tiny check valve about the size of the tip
of my thumb. These check valves are in the vacuum line connected to the
nipple just rearward of where the PCV valve hose connects on the passenger
side of the engine. Just behind this check valve the vacuum line T's off that
goes to the cruise control mounted underneath the battery.
But when I went to put it on, I found that the new part lacked the proper
rubber hose fittings to install it. The new valve 4677204 has 3/16 nipples.
The new valve comes with only one rubber reducing elbow which has a female 3/8
end, and the other end 3/16 female.
The original check valve 4306923 has 1/4 plastic nipple ends and has a 1/4
rubber female elbow on one end, and short length of 1/4 rubber hose on the
other. The new valve's 3/8 rubber elbow is wrong - too big to seal to the 1/4
nipple at the intake manifold.
I went back to the Dodge parts counter to ask for the proper rubber fitting to
make it work, but they said they didn't have them and suggested I would have
to go to a parts store. At the local Advance Auto I could not find exactly
the right fittings, but was able to put the new check valve on using slightly
smaller fittings:
Motormite Mfg. Vacu-Tite! pn 47411 rubber elbow with 9/64 and 7/32 id ends,
and Motormite Vacu-Tite pn 47411 rubber straight with 9/64 and 5/32 id ends.
Seems sloppy on Chrysler's part - but maybe later model Rams than a 1995 have
different sized vacuum hoses and manifold fittings ?
