no bus ??????
Old Jul 14, 2006 | 09:27 AM
2001ramsport's Avatar
2001ramsport
Default no bus ??????
on my way to work this morning and all of a sudden my ABS & CE. light came on,and I lost all of my gages.and the odometer was flashing NO BUS.then about 30 seconds later all was fine. what the hells up with that ?
Old Jul 14, 2006 | 02:01 PM
2001ramsport
Default RE: no bus ??????
Help!!!! Anyone??????????
Old Jul 14, 2006 | 09:19 PM
fiveliterbtr's Avatar
fiveliterbtr
It's most likely a PCM problem, "no bus" means no communication...could also be a bad ground, bad connection at the PCM, or a bad instrument cluster...The PCM is usually at fault. It's not anything that can be diagnosed over the internet, best take it somewhere.
Old Jul 17, 2006 | 06:21 PM
JKPalmer's Avatar
JKPalmer
Ok so I msged you yestarday for updates. And I ended up taking it in this morning to see what the problem was and they say i need the whole curcuit cluster replaced. The part itself cost 615 bucks. I hope that you don't have this same problem [:'(] Good luck with yours.
