What size is the freakin hub nut?
Old Jul 17, 2006 | 04:02 PM
Bigfoot68's Avatar
Bigfoot68
Default What size is the freakin hub nut?
I guess the subject line sums it up. I have to replace the drivers side axle u-joint and found I don't have a big enough socket. So does anyone know what size I need to get from Sears?
Thanks.
Old Jul 17, 2006 | 04:08 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: What size is the freakin hub nut?
1-11/16"
It's a big boy
Old Jul 17, 2006 | 04:48 PM
mojo's Avatar
mojo
AutoZone and AdvanceAuto carry them too. I bought mine at Auto Zone for $9.99 I thought it was 1 3/4" but after I wacked all the grime and rust off it was 1 11/16". You also need a torque "impact" wrench capable of 175 ft/lbs. I tried a 2 ft braker bar and my fat 250lb behind and broke the bar. If you want you can also take out the 3 12 point 14mm bolts off the hub and pull it out as one whole unit. Just be carefull when pressing out the u-joint that you don't damage the hub.
Old Jul 17, 2006 | 08:52 PM
Bigfoot68's Avatar
Bigfoot68
Thanks for the help. I'll be picking it up tonight.
Old Jul 17, 2006 | 11:12 PM
dhvaughan's Avatar
dhvaughan
see this....
http://www.pavementsucks.com/tech/hub.php
getting the bearing/hub out of the knuckle is a pita. some suggest beating on sacrificial bolts from the rear. others suggest using a shallow socket and extension and the steering as a press. someone else claimed to have replace the u-joint w/o pulling the axle.
do searches at pavementsucks, here, dieseltruckresources, etc for more info. good luck. post results.
Old Jul 19, 2006 | 01:15 PM
Bigfoot68's Avatar
Bigfoot68
It's done. After reading everything I was ready for a fight with the hub/bearing. But I removed the 3 bolts, wiggled the hub by hand, and off it came. It took about 45 minutes total to do. Again, thanks for the info guys.
Old Jul 19, 2006 | 07:42 PM
radwebster's Avatar
radwebster
ORIGINAL: Bigfoot68
lucky SOB. i ended up caving and destoying both my hubs by slamming them with a 4 pound sledge like 200 times
Old Jul 21, 2006 | 02:48 AM
theyellowdart's Avatar
theyellowdart
When i did mine i beat on it for hours before deciding to get some PB blaster- sprayed it in there and it was off in two min no problem- PB blaster is the **** the best penetrating lube ever!
Old Jul 21, 2006 | 07:30 PM
next level's Avatar
next level
i wanna know how someone did it without pulling the axle...
that takes some skill..
or someone bull****tin you
