1999 Dodge Ram 1500 truck A/c
Old Jul 18, 2006 | 02:14 PM
browncow73's Avatar
browncow73
Default 1999 Dodge Ram 1500 truck A/c
Seems to be a very "hot" topic.. Dodge truck blows out hot air. Compressor doesn't seem to come on/off.
I'm assuming it has R134 in it and see refill kits. How many do you buy for this vehicle. 4.3L. Is it easy to do?
Thanks.
Old Jul 18, 2006 | 02:24 PM
dodgedlr's Avatar
dodgedlr
Default RE: 1999 Dodge Ram 1500 truck A/c
Not sure what is included in these over-the-counter refill kits.
First find out WHY your compressor doesnt kick in - is it low on 134, or is it an electrical problem.
If it is low on 134, find out where it is leaking from...fix leak
Then evacuate the system for 20 minutes, and give it a full charge.
There will be a label in the engine comp. telling you what a full charge is.
Old Jul 18, 2006 | 04:24 PM
2001ramsport's Avatar
2001ramsport
shuold hold 2 lbs of R134A.
Old Jul 18, 2006 | 06:34 PM
2big2dodge's Avatar
2big2dodge
i ran into this once, just recharge it and you should be good to go. the old stuff is prob just freezing it to where the compressor cant kick on, so it blows hot.
Old Jul 18, 2006 | 07:19 PM
HuntinHanson's Avatar
HuntinHanson
just go to wal mart and buy a recharge kit. you'll probably need two people if your compressor isnt running to turn the air on and off. the compressor needs to be running for the system to take in a charge. Keep in mind if it hasnt been working for a while there is nothing in there to lubricate the seals inside the compressor and if they dried up and cracked you may need a new compressor to avoid it leaking out every time you re charge it.
Old Jul 18, 2006 | 08:11 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: browncow73
4.3L
Check your engine size again Dodge doesn't have a 4.3L truck motor. [8D]
Old Jul 18, 2006 | 08:29 PM
dodgedlr's Avatar
dodgedlr
Ha, I didnt even catch that.
