Viper rocker installation
Old Jul 25, 2010 | 01:29 PM
aim4squirrels's Avatar
aim4squirrels
that I do not know for certain. Green machine has some 1.7s that are not HS, but I don't know what he paid.
You can get th HS cheapest from www.southeastperformance.com
Old Jul 25, 2010 | 02:05 PM
BigRedRam95's Avatar
BigRedRam95
I can only find two sets for a magnum engine.
Old Jul 25, 2010 | 02:09 PM
lastrights's Avatar
lastrights
here is how to install them https://dodgeforum.com/forum/2nd-gen...r-rockers.html
Old Jul 25, 2010 | 02:57 PM
CPTAFW163's Avatar
CPTAFW163
Originally Posted by BigRedRam95
I had never seen this befor.
Someone is trying to sell me a set
if doing a CAM you want to go with 1.6 ratio. Because you end up messing with the cam grind specs. More is not better when talking about lift. So staying stock is worth it.
Matching the Cam to the intake and heads is what you want to do. Not using a mix and match of parts where the sum equals the most flow and the most lift. I did that 8 years ago and it was a DISASTER.
Going with 1.6 full rollers might get you 8HP at the rear wheels on a 1.6 ratio. So stay stock if doing a cam. If you don't want to do a cam, get the 1.7s. You will be happy when you are able to hold 85 MPH a lot easier on the hwy without staying heavy on the throttle.
Old Jul 25, 2010 | 03:23 PM
BigRedRam95
That was where I am kinda stuck because I want to do a cam just dont know when. I am kinda leaning on this one
http://www.summitracing.com/parts/CCA-20-744-9/
Then these rockers I just found
http://www.summitracing.com/parts/CCA-1425-KIT/
Old Jul 25, 2010 | 08:14 PM
BigRedRam95
let me ask you something else if it were you putting a cam in would you replace the heads or just have the stock reworked
Old Jul 25, 2010 | 08:38 PM
CPTAFW163's Avatar
CPTAFW163
I was looking at those rocker arms as well. DO NOT BUY! THEY ARE NOT FULL ROLLER ROCKERS. Just roller TIP.
PLUS, you need to get different sized pushrods (And hardened because you are using guideplates). I know because HUGHES sells those roller rockers and I called and asked about them. They are also not Bolt on like the Harland Sharps.
THe good thing about the Harland Sharp 1.6 NON ADJUSTABLE is that they are full roller, and do not need different length pushrods.
http://www.summitracing.com/parts/CSP-S70036/
They are actually less expensive since you do not need to buy a set of pushrods. THe pushrods run 98 (I think) at hughes:
http://www.hughesengines.com/Index/p...=&partid=25405
Old Jul 25, 2010 | 08:47 PM
CPTAFW163's Avatar
CPTAFW163
Depends on what cam. You should read this post:
http://www.bionicdodge.com/bionic/in...p?topic=9197.0
Parts:
KRC RV Cam (Have to call and order the 200/206 .480/.480 RV cam)
Stock kegger
1.6 RRs (Crowers...he got them used but they are VERY expensive)
Stock RT Heads (Don't flow much better than the non RT...they just have 2.02 valves)
It was dyno tuned
If I were you, I would just get the 1.7s and these heads (And a SCT from hemifever with the custom tune for those heads):
http://www.hughesengines.com/Index/p...2&partid=25426
Hughes raised their prices THIS YEAR for those heads. They used to be 799. Now they are 850. Must have been popular.
Old Jul 25, 2010 | 09:43 PM
BigRedRam95
Parts:
Stock kegger
It was dyno tuned
Well this is the cam I think I want.http://www.summitracing.com/parts/CCA-20-744-9/
Also I cant get the sct because my truck is a 95 I do have a MP computer
