P0171 system too lean bank 1
Old Jul 19, 2006 | 08:49 PM
dualstr8pipes's Avatar
dualstr8pipes
Default P0171 system too lean bank 1
My check engine light is on. Ugh [>:] The code is number P0171 says that the systems is lean in bank 1. What does this mean and how do I fix it? Heard that it might be an O2 sensor but which one, how do I tell? Don't want to buy both or buy the wrong one. Yes the cat is off but it has ran fine without it and no check engine light for 8 months now. So I don't think its that. The truck will idle real rough. down real low then up high back and forth. Sometimes just has no power at all. HAD TO PUT IT LOW RANGE TO TAKE OFF ONE TIME SO I DIDN'T SLIP THE CLUTCH THAT BAD!! If u let any pressure off the accelerator, not completely let off, just release a little it will jump it surge. What is wrong with my truck? Any help please. Seriously thinking about going for a new crew cab duramax.
Old Jul 19, 2006 | 09:08 PM
dodgerules86's Avatar
dodgerules86
Default RE: P0171 system too lean bank 1
Bad oxygen sensors should throw differant codes (P0130 to P0167), so I would take the guess and say its not the sensors (but I can't say for sure). As I understand it, the upstream oxygen sensors tell the computer to richen or lean out the fuel, the downstream tell the computer if the catalytic converter is good.
Oxygen Sensors:
Bank 1 Sensor 1 - Upstream Left
Bank 1 Sensor 2 - Downstream Left
Bank 2 Sensor 1 - Upstream Right
Bank 2 Sensor 2 - Downstream Right
As I said in the other post: don't. In a word: Cummins.
Old Jul 20, 2006 | 11:49 AM
fiveliterbtr's Avatar
fiveliterbtr
Could be a vacuum leak or faulty injector...
Old May 24, 2010 | 02:11 PM
young1014's Avatar
young1014
my 01 dodge is doing the same thing as of yesterday, engine light came on, code reader said the same code (system lean-bank1) . did you figure out what was wrong?
Old May 24, 2010 | 02:18 PM
What's with folks not looking at posting dates? This thread is four years old, the OP has 12 posts, and hasn't been seen since july of '06. Seems logical to assume you are NOT going to get an answer from him......
Start your own thread. Post your vehicle and problem.
Threadomancy should be illegal.....
Old May 24, 2010 | 02:28 PM
jamesnb's Avatar
jamesnb
Welcome to the forum young1014. I would start a new post and tell us about your situation.
Heyyou--Give him a break, at least he did a search instead of jumping in with new post that's been answered a 1000 times.
Old May 24, 2010 | 02:31 PM
young1014's Avatar
young1014
thank you jamesnb, put up a new thread
