Tranny slip????
Old Jul 20, 2006 | 12:09 PM
JJF's Avatar
JJF
Default Tranny slip????
I have had this problem for a couple months now, when I use cruise control on the highway above 60mph, the tach jumps 200-300 rpm. I doesn't do this if I cancel cruise and try to hold the same speed with my foot. The truck barely goes faster when this happens. Has anybody ever heard of this before?
Old Jul 20, 2006 | 12:13 PM
2001ramsport's Avatar
2001ramsport
Default RE: Tranny slip????
SOUNDS LIKE A BAD THROTTLE POSITION SENSOR
Old Jul 20, 2006 | 12:29 PM
mavrik's Avatar
mavrik
start with getting a new tps.....sound like the static from the tps is making the ecm lock and unlock the trans.....at least this is the first place i would start.....fyi take the old tps out slowly and pay attention so that the new one goes in the same way...
Old Jul 20, 2006 | 12:30 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Rather than swapping sensors, head to your local FLAPS, such as Auto Zone, and have them run a diagnostic. They will do it for free and it's much more accurate and less nerve wracking.
Old Jul 20, 2006 | 01:16 PM
2001ramsport
a noisy TPS probably wont throw a CEL. and may not show up on a diagnostic check.
Old Jul 20, 2006 | 02:40 PM
mavrik's Avatar
mavrik
correct....the ecm will look at it like you laying into the throttle a little....
Old Jul 21, 2006 | 04:43 AM
JJF's Avatar
JJF
Thank you all for your help...I will try that this weekend
Old Jul 22, 2006 | 04:59 AM
Ram_Sport's Avatar
Ram_Sport
really tps, could be tqc slipping maybe? would a torque converter slip throw code?
Old Jul 22, 2006 | 01:00 PM
2001ramsport
yes ,a bat TPS will cause the the T.C. to unlock momentarly .the computer thinks it'a in WOT.that will make the rpm's jump 200-300 . A bad T.C. should throw a code.
