Do they make this lift kit?
Old Jul 20, 2006 | 02:29 PM
Fubba's Avatar
Fubba
Default Do they make this lift kit?
I have a 96 4WD 1500. I would like to lift it in order to get 35 X 12.50's on it. I already have aftermarket rims with a short enough offset to fit 33 X 12.50's now with no rubbing. I tow a lot as well which is another concern of mine. I want a 3" suspension lift that will still keep the rear of the truck sitting a little higher than the front. It would be nice if the truck was lifted 3" all the way around. Do they make a kit like this? I'm going to check on putting new gears in my axles tomorrow which needs doing for the 33's anyway so this will not be an issue.
Old Jul 20, 2006 | 02:39 PM
mavrik's Avatar
mavrik
Default RE: Do they make this lift kit?
yes...take a look at skyjacker or add a 2" inch spacer and 2" add a leaf in the rear.....if your looking for about 1.5" to 2" of lift in front plus a little stiffer i have some #038 coils for the front and then you could just get an add-a-leaf for the rear and be done...
mavrik
Old Jul 20, 2006 | 09:45 PM
HuntinHanson's Avatar
HuntinHanson
top gun customz has a cheap one too
Old Jul 22, 2006 | 04:54 AM
mikeah169's Avatar
mikeah169
May wanna try roughcountry.com
Old Jul 22, 2006 | 12:05 PM
Chopper1's Avatar
Chopper1
Rancho makes a 3" kit that comes with spacers in the front and an add-a-leaf for the rear. $300.
http://store.summitracing.com/egnsea...115+4294907804
