Help needed
Old Jul 21, 2006 | 12:35 PM
msmudman2000's Avatar
msmudman2000
Default Help needed
I have a 1998 dodge ram 1500 with a 318 and an automatic tranny with overdrive. My problem is when I accelerate to pass someone or take off from a stop and my airconditioner is on it is like the vacume is taken away from the air conditioner. I am thinking that I might have a vacume leak somewhere or one that is crossed up. Any ideas out there?
Old Jul 21, 2006 | 12:55 PM
azffighter's Avatar
azffighter
Default RE: Help needed
Mine does the same thing. I think it is coming from one of the hoses from above the compressor behind the glove compartment. It's a pain the @#$ to get to though. If that's not it I don't know where else it could be coming from. I've checked most of the visible vacuum lines to no avail. Let me know if you find anything out.
Old Jul 21, 2006 | 02:35 PM
TMS Bill's Avatar
TMS Bill
You mean that the A/C stops blowing cold when you gun it? Normal ops. The compressor cuts out to stop robbing the engine.
Old Jul 21, 2006 | 03:36 PM
msmudman2000
No what I mean Bill is that it stops blowing out the vents and starts blowing out either the defroster or the floor. It still blows cold air.
Old Jul 21, 2006 | 03:59 PM
The Burning Rom's Avatar
The Burning Rom
You have a vacuum leak somewhere. They can be buggers to find.
Check first to see if this service bulliten applies to you: http://dodgeram.info/tsb/1996/24-01-96a.htm
Old Jul 21, 2006 | 05:17 PM
TMS Bill's Avatar
TMS Bill
Well, so much for that. We're seeing a lot of this lately. You're down to checking for cracked, loose or disconnected vacuum lines, both under the hood and dash.
Read here: http://www.asashop.org/autoinc/may/TECH2TEC.HTM
and here: http://www.aa1car.com/library/vacleak.htm
Hope it's not a leaking gasket.
Old Jul 21, 2006 | 07:23 PM
Aperture_Disaster's Avatar
Aperture_Disaster
I had the Same problem... it was the CAD units vacuum lines from the transfer case. both of them apeared to be connected but upon closer inspection the plastic lines were craked near the rubber ends. if this is the problem... i have the part number and its 32 bucks from the dodge dealer. Hope you find it.. i know it can be frustrating. you are on the right path.
