Turn signals not working
Old Jul 23, 2006 | 06:02 PM
list's Avatar
list
Default Turn signals not working
All other lights working, but no turn signals (front or rear). Any ideas?
Old Jul 23, 2006 | 06:06 PM
dodgerules86's Avatar
dodgerules86
Default RE: Turn signals not working
Is it that they DON'T illumintate, or that they DO illuminate, but do not flash?
Old Jul 23, 2006 | 06:07 PM
list's Avatar
list
Thanks for the reply. They don't illuminate. I was able to get them to come on briefly by jiggling my keys in the ignition, but then they went out again.
Old Jul 23, 2006 | 06:18 PM
dodgerules86
Get a multimeter (voltmeter) and test for battery voltage at the turn signal flasher (a circular unit, it will be one of the two connectors; if you have a cube "Combination Flasher" there should be battery voltage at cavity 48 [I believe the cavities should be listed on the bottom of the unit, if not, just poke around] and 51) do this test with the key ON.
Old Jul 23, 2006 | 06:28 PM
list's Avatar
list
I will give that a try.
No indicators working on dash, no turn signals working outside. Hazards and other lights work fine.
