Mopar PCM, and tire size?
Old Jul 25, 2006 | 11:49 PM
Mike Roma's Avatar
Mike Roma
Default Mopar PCM, and tire size?
Is there a way to compensate for different tire size, and gear ratio with the ('96) Mopar PCM? If not, how can I make adjustments for tires/gears on my '96 Ram? I'd like to have different tires for track, and highway. Speedo does not need to be accurate at track, but I'd like to be able to switch between tires, and have the speedo correct if possible. I'll probably go with 4.10's or 4.56's.
Any suggestions?
Thanks!
Old Jul 26, 2006 | 12:38 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: Mopar PCM, and tire size?
On a 96, the PCM doesn't have a calibration for tire size. The truck has a speedometer gear IIRC that can be changed based on tire size.
Quoted from Dodgeram.org
the part number is 520676XX for the speedo gear, where XX is the number of teeth. If you have 31 teeth, like for 245-75-16 tires and 3.54 gears, it would be 52067631. The part number series available up to 38 teeth.
Old Jul 26, 2006 | 12:55 AM
vsraptor's Avatar
vsraptor
ok what about calibration for a 2000. it is had to accurratly do mpg with 265 tires when stock are 245. Assuming the trip od is not accurate. I think i read that on this forum.
Old Jul 26, 2006 | 01:41 AM
Mike Roma's Avatar
Mike Roma
Thanks, Rom. Is there a downside to performance with the "wrong" speedo gear, other than having the speedo/odo reading being incorrect?
Old Jul 26, 2006 | 01:45 AM
Mike Roma's Avatar
Mike Roma
Oh, yeah... does anyone know if the PCM will disable, or reduce torque management?
Old Jul 26, 2006 | 02:03 AM
The Burning Rom
ORIGINAL: Mike Roma
There's no impact on performance running the incorrect speedo gear. As far as torque management, it's debateable. Some say it does. Some say it doesn't. The way I see it, if you have a 92-96 Ram, you don't have a lot of choice anyway since the Perf. PCM is the only option out there.
ORIGINAL: vsraptor
The 2000 calibration has to be changed in the PCM, either by the dealer or by a hypertech/superchips programmer.
Old Jul 26, 2006 | 02:17 AM
vsraptor's Avatar
vsraptor
can a hypertech powerpac do this change? i might beable to get a better deal if so by this guy at a local muffler shop.
