Clicking noise
Old Jul 27, 2006 | 07:12 PM
DuranguenzeRam's Avatar
DuranguenzeRam
Default Clicking noise
Im getting a clikcing noise when i accelarate and also when i engage the brakes heavily doing about 30mph. If i dont take the truck over 30 i can apply brake without the clicking any thoughts? Ive had right bearign replaced along with recent brakes, the clicking started once the bearign was replaced. Im also running 20's on it could that have any effect. ALso the noise seems like from the rear....
Old Jul 27, 2006 | 08:44 PM
Socha_62's Avatar
Socha_62
Default RE: Clicking noise
Clicking is usually u-joints of some type. Most likely your rear drive shaft. You can pop the drive shaft off (its held on by 4 bolts) and see how freely the u-joints move
How many miles? 4x4?
Old Jul 27, 2006 | 08:47 PM
DuranguenzeRam
its a 4x4 barely hit the 100k mark u joints ill check them out once this heat wave passes wouldnt want to get crispy thanks for the help. lol
Old Jul 27, 2006 | 08:56 PM
Socha_62's Avatar
Socha_62
I recently replaced all my u-joints. Both driveshafts 5k ago and I just had to do my front axle ones because they were clicking really bad. I have 115k on my truck. I hope its not the axle ones. Cause its a PITA if you do it yourself, and expensive if you pay somebody.
Old Jul 27, 2006 | 10:49 PM
desert dodge's Avatar
desert dodge
I had the rear clicking noise as well
changed the rear u-joint and boom clicking no more
btw if you do it yourself be carefull w/ the needle bearings theres alot of them and can make an easy fix turn bad
Old Aug 2, 2006 | 05:58 AM
New_Climber's Avatar
New_Climber
When you say rear u-joints do you mean rear drive shaft u-joints??? Is there u-joints on the rear axle?? I also have clicking, but have replaced both front bearings, u-joints on the front axle and pulled the front drive shaft and it was still clicking so the drive shaft is not a problem.
By the way, the front axle was easy...just need to get the axle hub nut off so I could get the bearing off, and then carefully pulled the axle shafts...
Old Aug 2, 2006 | 08:30 PM
Socha_62's Avatar
Socha_62
Yes rear driveshaft. The rear axle has no u-joints.
Old Aug 3, 2006 | 02:35 PM
DuranguenzeRam
Well took it in to the shop they replaced front left u joint and the drive shafts along with left tie rod but the noise still there i think im goin to go back since he said the noise would disappear. Dissapeared for 30 mins right back this morning got the good old crickets on my drives still along with the crackling sound.
Old Aug 3, 2006 | 02:48 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
U-Joint maintenance is something I would not put off. Nothing worse than dropping the driveshaft while cruising along at 50+ mph.
