I'm SOOO screwed
I'm SOOO screwed
Engine was missing when cold, so I figured that I'd do a tune up: new plugs, wires, cap and rotor as well as TPS. Get to plugs and the first one I tried (rear driver's side--is that 7 or 8?) sheared off. Yep, the bottom of the plug is still in the hole but the part that your wrench can grab is in my hand.
And if it's in there tight enough to break the plug, I'm guessing that no half-assed solutions like JB Weld or something like that will work, either.
So do I have a trip to the dealer in my future? I don't have time to do an engine tear-down and I really need my truck for my business. Any other suggestions? Much appreciated.
F*&k.
F*&k.
RE: I'm SOOO screwed
listen, this happened to me. if you can unscrew the plug all the way they make these sring loaded rods that when you push on the plunger at the top the bottom opens up with 4 prongs. you will be able to grab the plug with this.i cant remember the name but its a good tool for reaching behind stuff to pick up what ever is dropped. and if the plug is stuck in there then it was probably threaded wrong during install
When you say you broke it off, do you mean just the insulator (white part)? Or the body (metal hex part) of the spark plug as well? If you broke the body of the plug, then you were putting waaaaay too much force into it If you just broke the insulator, then it can still be removed VERY carefully.
If you indeed did break the metal hex part off, then there's nothing that will get them out. You'll have to pull the head and drill them out.
ORIGINAL: The Burning Rom
I'll probably just take it to the stealership and have them fix it. They can do the plenum, the cat recall, the leaf spring TSB and fix the A/C all at the same time. Since the bill will be big anyway, I may as well get it all done. That way the wife only freaks out once
I'm feeling better, but man, this sucks. What's worse is the truck is now immobile in my driveway and both of my other cars are trapped in front of it. How many friends do you think I'll need to push a 2500 4x4 extended cab long bed up the hill?
Tell me about performance heads...
Thanks guys.
this happened to me too.......four out of eight broke off and the hex was in my hand........my mechanic was able to use easy out and get them out without taking the head off, thank god ,i dont know how he was able to do that but i dont care as long as the heads didnt have to come off.....but like tani said if i had to do that i would of gotten the performance heads.....lol
happend to me but not on my ram . but on my dads explorer. if the hex came off.. is the porcelin still intact? what happend with me is that the hex sheerd off, then the porcelin broke and slid out leaving a nice size hole a EZ out fit into.. had to run an impact on it with an EZ out at the end of it .. but it worked.. saved my dad lots of $$$
Trending Topics
find a way to move the truck out of the way to get your other cars out, then go buy the tools you need to yank the plug out. if you cant get it out... f*&^ the dealer and yank the head yourself... if you end up doing it yourself (which you can... with great support here at DF) either get the heavy duty heads with an ARP headbolt kit and swap both heads out. stock heads suck and it's a waste to put it back on. bare HD castings are 250~300??? (havent checked lately) your motor will be much happier.
sorry to hear about that happening.... sucks asssssssss
you might try some penetrating oil to see if that will loosen it up. it might just be rusted in there a bit.
to move the thing... shouldn't take more than a few friends... ten.. fifteen maybe... i can push my 1500 ex cab short bed by myself if i put it in neutral and just coast. but that's on flat ground.
