Common trans problem?
Old Aug 1, 2006 | 11:30 PM
got4wd's Avatar
got4wd
Default Common trans problem?
When I first start my truck in the morning and put it in rev or drive. It takes a few seconds for it to engage. My old jeep had the same problem. Anyone else have this problem when you first start off in the day? 99 dodge 1500
Old Aug 1, 2006 | 11:46 PM
DieselDemon's Avatar
DieselDemon
Default RE: Common trans problem?
Pump problem? Maybe a valve body problem. Could be the TC is being allowed to drain.
Old Aug 2, 2006 | 12:10 AM
The Burning Rom's Avatar
The Burning Rom
Did you check the fluid level?
Try letting it sit in neutral for a few seconds before slipping it into drive. The pump won't circulate fluid when it's in Park.
Old Aug 2, 2006 | 12:34 AM
gstrbel30's Avatar
gstrbel30
My truck does it when it sits for a few days.
Old Aug 2, 2006 | 06:08 AM
got4wd's Avatar
got4wd
It's full. I am going to do the pan gasket and filter change tomorrow. Not a big problem, just wondering if anyone else had this problem.
Old Aug 2, 2006 | 10:28 AM
Chopper1's Avatar
Chopper1
Make sure you use ATF+4 fluid. Autozone has it as do some others.
As ROM said let it idle in neutral for a few before taking off. This also applies to extended parking with the truck idling. The fluid will heat up since it is not flowing through the cooler, so consider neutral with the parking brake on.
Old Aug 2, 2006 | 11:03 AM
Biggmee's Avatar
Biggmee
Maybe this is a rookie question but; is it a good idea to let the the vehicle sit for a few seconds, in neutral, upon the first start-up of of the day?
I hope so, that would give me a good excuse to do a neutral drop each morning out of my drive-way!
Old Aug 2, 2006 | 07:00 PM
The Burning Rom
ORIGINAL: Biggmee
Yeah, it is a good idea as it gets the fluid moving before the truck starts moving. Neutral drops are a bad idea though
Old Aug 3, 2006 | 02:54 AM
got4wd's Avatar
got4wd
Well I can't get rid of the leak. Looks like it is leaking out of the converter. Common?
Old Aug 4, 2006 | 12:24 AM
DODGERAM808's Avatar
DODGERAM808
if its leaking out of the trans that is not a good sign. i just blew my trans and it poured fluid out of the bellhousing and white smoked everywhere. i blew the converter apart.
