1998 Ram 5.2l Performance options
Old Aug 6, 2006 | 08:43 PM
01ramclassic's Avatar
01ramclassic
Default RE: 1998 Ram 5.2l Performance options
ORIGINAL: AWD DSM 1
This I don't know... although it never threw a CEL light before. I'd imagine if the o2 or a sim wasn't installed I'd get a CEL.
ORIGINAL: 01ramclassic
You said that it had the cat removed....Does it have an o2 sim in the o2 sensors place? If it doesn't then that would be the reason for the misfire I believe.
I would still check that out. Just look under the truck to see if the 02 sensor was put back into the exhaust before the muffler, If it has an o2 sim then the sensor would be hooked up to it and zip tied to the frame of secured some other way and not in the exhaust pipe.
Old Aug 6, 2006 | 09:28 PM
AWD DSM 1's Avatar
AWD DSM 1
Both o2's are there... is the cat the little thing right at the "Y" in the Y-pipe? If so, then I guess it's still there. Maybe it's just a pre-cat?
Old Aug 6, 2006 | 09:30 PM
AWD DSM 1's Avatar
AWD DSM 1
Also just got the heads off and confirmed that I blew the DS head gasket between #3 & #5.... funny thing is that they aren't stock. These were Fel-pro's. Are these supposed to be good head gaskets, or is there somthing better I should look for this time?
Old Aug 11, 2006 | 01:36 AM
AWD DSM 1's Avatar
AWD DSM 1
Started cleaning some things up today, and noticed that one of my lifters apparently got spun out of the keeper and chipped the corners off. Can you replace only a single lifter, or should they be done in sets?
