overheating
Old Aug 7, 2006 | 03:05 AM
muddy_blue_dodge's Avatar
muddy_blue_dodge
Default overheating
ok.... my trucks been overheating quite a bit recently...... temperatures around here have been in the high 90s and occasionally breaking into triple digits. is this why its overheating? or should i be worried that something else might be wrong? i have the stock t-stat (195 i believe).... and the trucks always run right at 200. but its been well over that recently, sometimes getting up to about 220 (when it gets that hot i pull over and turn on the heat for a while to let it cool back down)
im just wondering if yall think its the heat or if something could be wrong?
Old Aug 7, 2006 | 03:22 AM
ChaoticBastard's Avatar
ChaoticBastard
Default RE: overheating
My truck runs right at the 200 line or a tad above.I just hit 120K so I am going to swap out the waterpump and tstat being that they are the original.Sometimes the impellers on the pumps can disentigrate and it wont give you the normal signs of the pump being bad.Depending on your milage it might be something to consider.
Old Aug 7, 2006 | 03:25 AM
okiemag318's Avatar
okiemag318
I think it might be something else. I have a black dodge with the stock t-stat and it has been over 100 degrees, up to 107, for at least 3 weeks, probably more. The only problem i have had with overheating was when i let my truck idle for a while, but as long as i am driving it always stays around the normal temp, 200 or so.
Old Aug 7, 2006 | 03:42 AM
shott8283's Avatar
shott8283
it hit near 100 here for 3 days straight,, stop and go traffic/gridlock for an hour with windows up and ac blowin i never went over 180ish (180 tstat) thats WITH elec fan coversion
you have a cooling system problem. especially with the stocker fan..
Old Aug 29, 2007 | 06:23 PM
rvert10's Avatar
rvert10
I'm having a simular problem on my 2000 3500/5.9L diesel when towing. I leaning toward the radiator cap or I'm trying drive like a teenager I'm pulling approx. 12000 fifth wheel and have never had the needle peg and the warning lights. before I go to the dealer I'd like other advice.
and as shott8283 says I'll say I am a teacher and I am a retired senior NCO (RVN 68-69)
Old Aug 29, 2007 | 06:54 PM
mopar98's Avatar
mopar98
Muddy it could be one of three things in my mind
Clutch fan could be taking a dump.
Thermostat might not be working right.
Also could be the water pump.
Old Aug 29, 2007 | 07:56 PM
WayneC's Avatar
WayneC
How old is the coolant? Test it with a cooant tester.If not up to snuff, Then try a flush, refill.
Old Aug 29, 2007 | 08:43 PM
motorbrreath's Avatar
motorbrreath
might as well swap the t stat out, its only a 5 dollar part.
