speedo
Old Aug 8, 2006 | 02:07 PM
White Ghost's Avatar
White Ghost
Default speedo
1999 dodge ram 1500 speedometer only works at about 70 and higher.........what do i need to do????
Old Aug 8, 2006 | 06:30 PM
mojo's Avatar
mojo
Default RE: speedo
Look at the speed sensor make sure its not broke if thats not it then the speedo cabble could be broke.
Old Aug 8, 2006 | 11:14 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: speedo
Speedsensor...either the one in the transmission or the one in the rear-end (if your truck is a 98 or newer).
If it's neither of those, then you have a bad ground somewhere...probably in your cluster.
There is no speedometer cable. It's all electrical.
Old Aug 9, 2006 | 02:05 PM
White Ghost
Default RE: speedo
thanks for the reply,Iwas driving at the time it started acting up,witch one would you start with???
Old Aug 9, 2006 | 02:14 PM
steve05ram360's Avatar
steve05ram360
Default RE: speedo
start with the speed sensor on the rear diff. takes about 10~15 min to swap max and is less than $40 bux. IIRC it's a dealer only item but im not 100% sure.
