what size tires?
Old Aug 8, 2006 | 06:29 PM
HUGE_RAM's Avatar
HUGE_RAM
Default what size tires?
hey everyone, i have a 95 ram with 199xxx miles on it. its mostly just a mud boggin truck, its not regeared, and pulling 35" tires. will the tranny and axle be able to handle 38"s or are they too tired? i will regear soon after i put on the 38", just want to know if it will be ok for a little while. Thanks for any advice.
Old Aug 8, 2006 | 08:16 PM
Big_N_Bad's Avatar
Big_N_Bad
Default RE: what size tires?
I dont see a problem with running 38s, actually you may run into a bit of a prob, axle seals I go through them quite often, and I might think that mud may get into your axle through a bad axle seal, That would be the only problem i see, you might also go through hub berings faster, other than that you are good to go,
BNB
Old Aug 8, 2006 | 11:12 PM
The Burning Rom's Avatar
The Burning Rom
You're going to lose your ability to drive it on the highway if you go to 38s without regearing.
I would also worry about the u-joints and wheel hubs/bearings. If they've never been replaced, they won't last very long. If they've been replaced, they'll last a bit longer. Putting that large of a tire on (along with a rim to run them) will definitely stress the axles...especially the front one.
