Mods List and SHOTT got a Question
hey here are my future mods I am listing them to see if they will all work together,
1,New Cap and Rotor(need advice on brand)
2,Throttle body(fastman)
3,6x9 k&n filter( shott, i need the deminsions for this percisly the shop needs like the end cap spec BC they order it by the deminsions Thanks)
4,Deep Trans pan(need advice on brand)
5, Mopar valve covers(I like silver_dodges)
6,New intake manifold(need advice on brand)
7,plenum gasket rienforcement kit(hughes)
8, Gasket kit(hughes)
9,Borgeson steering shaft,
10,Electric fan(flexilite)
11,oxygen sensors
12, This should have been farther up but Roller Rockers(which brand)
Well guys what do you think, will all of them work together and with my mods aleady, And any advice and brands for the parts above is a great help
BNB
11,oxygen sensors
BNB
i say go for a k&n cold air intake instead of the filter itself
Trending Topics
Thanks guys, I have the CAI however the filter that shott gave deminsions for flows like 500 more CFM than the one provided in the kit. Thanks tempsho but have already replaced with those spark plugs. Thanks guys and keep it coming
BNB
BNB
ORIGINAL: Big_N_Bad
11,oxygen sensors
BNB
11,oxygen sensors
BNB
1) Mopar Cap & Rotor... I saw no benifit from aftermarket ones when I had my truck.
2) Fastman is the only way to go IMO, depending on what your after...
50mm for a 318 average/daily driver or 52mm if you want hi end HP.
52mm for a 360
3) the 6x9 filter from K&N will cause you to loose a little low end torque so keep that in mind. It will help out alot on the top end though.
4) TCI or Mag Hytech <- have this one on my '05
5) you have your answer already... there arent many choices.. either black or polished
6) Depends on what truck you have and what you want out of it...
Stock manifold with mods for a daily driver
M1 for hi end HP
7) anyone of them will work. you wont need it if you get the M1 manifold
8) if you have the stock intake on, get the felpro plenum gasket
9) can't comment
10) flex-a-lite is always a good option... get the spal fans (s-blade ones)
11) NGK's
12) Crower Roller's, the kit includes the push rods and guide plates which are recommended for rpms above 5k.
HTH...
