Wheel Changes Center Hub Problems
Old Aug 9, 2006 | 04:00 AM
Rskeab's Avatar
Rskeab
Default Wheel Changes Center Hub Problems
First time user here and prowd Ram Owner,
I just aquired from a friend his wheels and brand new tires from a 2001 Ram 1500. He needed an upgrade. The wheels are the same bolt pattern however the front hubs on the 2001 are significantly different from my '96. Is there a hub conversion kit out there or are spacer's the only option? Any and all advice her would be very helpfull. Thank you all,
~Rskeab
Old Aug 9, 2006 | 10:54 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Wheel Changes Center Hub Problems
The hub difference doesn't matter. The 2000+ hub is a better design, but the wheels should still fit your truck. The only area you might have a problem with is the rear wheels that have to slip over the drum.
As far as spacers, you should NEVER run them on a truck...or ANY vehicle. They are NOT street legal for a reason.
Old Aug 10, 2006 | 04:32 AM
crazy1snow's Avatar
crazy1snow
hmm i should really do the math and figure out the added torque that spacers add to the hub... na too much work. too much statics for me. i do believe it is something like 5000 lbs though... so.... DON'T DO IT!!!!!!!!!!!!!!!!!!!!!!!!!!!
