need help with my gas mileage
Old Aug 11, 2006 | 09:36 PM
southrncomfort05's Avatar
southrncomfort05
Default need help with my gas mileage
well i jsut bought a 99 ram with a 6 inch body lift and it has 35x12.50 buckshoot tires and im getting about 10.2 miles to the gallon i dont have alot of money to do the gears in it is there anything else i can buy to get my mileage up any help would be appreciated
[IMG]local://upfiles/41868/2452A237B75E49AF80A64181F729E520.jpg[/IMG]
[IMG]local://upfiles/41868/A3229A61A64944D3817B65F443F10E0D.jpg[/IMG]
Old Aug 11, 2006 | 09:41 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: need help with my gas mileage
Change your tires to a smaller size, like 33's or smaller. Also, a light weight tonneau cover can help if you do a lot of highway driving. Gears are still going to be your best option though if you want to keep the 35's.
Old Aug 11, 2006 | 10:58 PM
Ram1500Dodge's Avatar
Ram1500Dodge
i got some 32 inch All Terrains ill trade you.....
Old Aug 12, 2006 | 03:09 AM
fiveliterbtr's Avatar
fiveliterbtr
Do all you want, but the best possible consistent mileage will be around 15-16...we bought a giant aero-inefficient truck, I know I didn't buy it for the mileage
You'd be better off buying an old lil' Civic or Neon for daily driving by the time you're done spending $ to improve the truck's mileage.
Old Aug 12, 2006 | 03:13 AM
radwebster's Avatar
radwebster
did you honestly expect any better? there is no easy cheap way to make any noticable difference. otherwise the factory would have done it. go buy a prius if you need better mileage.
Old Aug 12, 2006 | 03:19 AM
Redone4x4's Avatar
Redone4x4
sounds about right for a big a$$ truck with big tires, even with big gears. gears would probably make you step in it some more, but wouldn't hurt the tranny so much as stock ones will. either way, the truck shouldn't get more than 10-13 mpg IMO.
Old Aug 12, 2006 | 07:55 AM
Chopper1's Avatar
Chopper1
Nice looking ride..
Unless you have had the speedometer calibrated the mileage is off and you are getting better than you think. When I went to 35's, my actual mileage and speedo was roughly 10% off. At 70 I was really doing closer to 77. Took a trip and my buddy's truck with stock tires was going close to 10% farther according to his speedo when we would fill up.
So when you write down the mileage, add 10%,(270+27), and it will be closer to your actual MPG.
Old Aug 12, 2006 | 02:12 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
do your own math tho...... it may be off of 10% by a little...... just to be exact
Old Aug 12, 2006 | 05:52 PM
HankL's Avatar
HankL
here's a weblink to a long article with many ideas on improving MPG of Ram pickups
https://dodgeforum.com/m_447500/tm.htm
as others have said
with the 6 inch lift and large tires
you are starting out far behind
because the aerodynamics and tire rolling resistance
are greater than a stock truck
If you must stay with large diameter tires
consider buying the 19.5 commercial tires and rims
when your present tires are worn out
