Brake/Rotor/Axle assembly.....help
Old Aug 14, 2006 | 11:53 PM
Capema00's Avatar
Capema00
Default RE: Brake/Rotor/Axle assembly.....help
ok so.........
GREEN - caliper bushing
BLUE - slider pin
WHITE - bolt
sorry for not totally understanding the vocab, but please correct me if i'm wrong
[IMG]local://upfiles/41971/90C97C99B0404B58AE55987D716EC63B.jpg[/IMG]
Old Aug 15, 2006 | 01:36 AM
DieselDemon's Avatar
DieselDemon
That's a pic of your new caliper? I don't remember if there is a difference between 95 and 97 calipers. The arrows are correct. Only on my caliper that bushing is shaped differently. That pic is the EGR big brake caliper I believe. EGR's set up uses a poly urethane bushing instead of rubber. That's is their own blueprinted caliper in that pic. If you run to an auto parts store, look at your caliper new in a box. You will see what I mean.
Good luck
Old Aug 15, 2006 | 02:09 PM
Capema00's Avatar
Capema00
yea that's not mine, i just googled it and found one i felt looked similar. that's how the calipers look on my truck, but anyway, thanks for the help, i appreciate it.
-andrew
