Screamin demon coil
Old Aug 16, 2006 | 05:04 PM
Redskin57's Avatar
Redskin57
Default Screamin demon coil
I need to do a tune up in the near future. Was thinking about changing to a high output coil. Has anyone used a Screamin Deamon coil. I plan to use NAPA Cap and rotor (I think they are brass) bigger wires and plugs (can't remember the number but know it is in several posts). Coil is kind of an after thought. You know hotter spark better burn type thing.
Old Aug 16, 2006 | 11:51 PM
bigdodgeram's Avatar
bigdodgeram
Default RE: Screamin demon coil
I just switched to a MSD coil. it was like I changed the spark plugs, and just took delivery of the truck.
Old Aug 17, 2006 | 12:31 AM
Tani1500's Avatar
Tani1500
i put them MSD in mine along with there 8.5 wires and new plugs, cap.... i did the coil about a day after the wire and everything where changed. it seamed to give it a smoother idle but thats as far as i noticed. i would definatly buy one again though. i had a wire missing and you could see the spark was a much hotter and bigger spark then the stock unit.
Old Aug 17, 2006 | 11:35 AM
Redskin57's Avatar
Redskin57
Thanks guys. My first thought was an MSD they have been around along time. I thought you had to use their complete system. I just didn't want to put that much into upgrading the whole ignition system at this time. I just got a Fastman TB so was going to keep the coust down. May save my money and change the whole system.
