O2 sensor replaced, still getting CEL
Old Aug 18, 2006 | 03:12 PM
Ag99JYD's Avatar
Ag99JYD
Default O2 sensor replaced, still getting CEL
Ok, I replaced the O2 sensor on my truck and I'm still getting a CEL.
Specifics:
97 1500 5.9 L
Code was P0138
Replaced sensor AFTER converter.
After searching around trying to figure out what Bank 1 Sensor 2 was, there seemed to be evidence that there are 4 O2 sensors - I only found 2. Did I replace the wrong one? Do I need to have the CEL code cleared with a scanner to make it go away?
PS - I used the OE part from Autozone. I know, MOPAR would have been better. But hey, I went back to school and money's tight!
Thanks in advance.
Old Aug 18, 2006 | 03:25 PM
RM_Indy's Avatar
RM_Indy
Default RE: O2 sensor replaced, still getting CEL
Disconnnect the battery for 20 seconds and turn the key on/off and reconnect the battery and see if its still throws the code
Old Aug 18, 2006 | 03:33 PM
steve05ram360's Avatar
steve05ram360
also check the wiring for any shorts to gnd... I had a heater wire melt onto the tranny and blew the heater fuse (I dont think you have one) which caused problems.
Old Aug 18, 2006 | 04:56 PM
Tommygunz's Avatar
Tommygunz
I have the same truck/motor. There really are only two sensors. There is a pre-cat actaully in the cat and a post cat further down the exhaust stream. If resetting your PCM doesn't work you may want to check out the other one as well. Also I just changed mine, I was smoking liek a diesel it failed so miserably, but I purchased a Bosch and the truck seems to like it.
Old Aug 18, 2006 | 05:26 PM
Ag99JYD's Avatar
Ag99JYD
That did the trick. I was unsure if you had to reset the computer or if it would go off automatically.
Also, thanks for the info on the number of sensors. I guess the bigger engines maybe have more.
Old Aug 18, 2006 | 08:09 PM
Ram_Sport's Avatar
Ram_Sport
nope, engine size shouldnt have to do with that cause one measures the mix of fuel to air in exhaust i believe and the other checks the functionality of the cat.
Old Aug 18, 2006 | 08:32 PM
steve05ram360
the newer trucks have 3 cats... one off each exhaust manifold and 1 behind both. I had this setup and it had 4 o2 sensors. At 1st I thought it sucked but having an o2 on each bank would keep the performance level up i'd think.
Old Aug 19, 2006 | 03:41 AM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: Tommygunz
There should be another sensor up closer to the motor. There shouldn't be one IN the cat.
There could also be up to 4 sensors on a truck depending on the emissions package
Old Aug 19, 2006 | 03:55 AM
fiveliterbtr's Avatar
fiveliterbtr
For what it's worth, "bank 1" is referring to the location of cyl. 1, which is the drivers front cyl. when looking from the front of the truck
"bank 2" would then be the pass side
"sensor 2" would indicate the sensor furthest from the engine, or downstream "sensor 1" would be upstream
