How to check Injector Wiring?
Old Aug 18, 2006 | 06:34 PM
smartobject's Avatar
smartobject
Default How to check Injector Wiring?
What can I do to check the power going to a fuel injector? (Don't say lick the contacts while it's running!)
I've seen write-ups that mention an oscilliscope, but was hoping there was some easier / less expensive method.
Was gettting a P0303 code, so cleaned all injectors and put #3 on Cylinder 7. It hasn't thrown a code yet, but the vibration / miss is still there and when I pull the connector on #3, I notice no change in idle. But when I pull others (and #7 which was the former #3) I do notice a change in Idle.
Thanks,
Lee
Old Aug 18, 2006 | 06:55 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: How to check Injector Wiring?
If there is no change at idle when you unplug the injector there's a chance the injector could be plugged.
Old Aug 18, 2006 | 07:39 PM
Ramdamit98's Avatar
Ramdamit98
My manual says you should be able to get a special injector harness test light (noid light) from most auto parts stores to check if your getting anything at each injector connector.
