Noise when turning
Old Aug 20, 2006 | 06:15 PM
toddyfresh's Avatar
toddyfresh
Default Noise when turning
Hey whats up i have a 2001 dodge ram extended cab 360 in it and when i turn the front wheels it sounds like metal scraping it is 4wd. any clues as to what it might be? i was thinking universals any thoughts?
Old Aug 20, 2006 | 06:56 PM
shott8283's Avatar
shott8283
Default RE: Noise when turning
bad hub bearings or bad axle ujoints... or a loose bolt on your caliper and it is dragging on the rotor
Old Aug 21, 2006 | 12:25 AM
The Burning Rom's Avatar
The Burning Rom
I'd lean more towards wheel bearings
Old Aug 21, 2006 | 12:49 AM
bamory's Avatar
bamory
Had same noise, wheel bearing was burnt
Old Aug 21, 2006 | 03:54 PM
spur's Avatar
spur
something easy and stupid that made mine make noise....the plastic shroud over the wheel to protect the engine from junk....it came loose on the back end and rubbed against my tire.
