messed up front end
Old Aug 17, 2006 | 01:30 PM
ramgirl's Avatar
ramgirl
Default messed up front end
I have a 98 ram 4x4, the problem is the front end. both tires lean in and the tower for the upper ball joint bends in. steering and ball joints are tight. has anyone had this problem and how is the best way to solve it?
Thanx
Old Aug 17, 2006 | 01:35 PM
fiveliterbtr's Avatar
fiveliterbtr
Default RE: messed up front end
2 wheel drive? Sounds like you're describing the upper control arms ("tower")...if that's the case, any shop that does alignments should be able to adjust it to specs...make sure they check your ball joints and steering linkage beforehand
Old Aug 17, 2006 | 02:26 PM
Socha_62's Avatar
Socha_62
2wd's don't have control arms
And if the tire is leaning and you said the ball joint moves, its shot. Swap them out!
Old Aug 17, 2006 | 02:29 PM
Tani1500's Avatar
Tani1500
its a 4x4, is the top of the steering knuckle bent? did this happen all of a sudden? to much camber maybe? what size tires you have on it. mine lean like that too with 35's but that just because there huge and this axle sucks.
whats wrong with you guys she said it was a 4x4 and the ball joints are tight
Old Aug 17, 2006 | 02:32 PM
Socha_62's Avatar
Socha_62
I can't read! Don't make fun of my disability [sm=alcoholic.gif] I'm not even going to try to explain myself, it'll be a waste of time[:'(]
Old Aug 17, 2006 | 02:45 PM
Tani1500's Avatar
Tani1500
hahaha
ram girl, does this look like its bent?
[IMG]local://upfiles/15914/5195CDE237DB4EF8A2BC3F36C18F52DA.jpg[/IMG]
Old Aug 17, 2006 | 03:23 PM
fiveliterbtr
ORIGINAL: Socha_62
You're kidding, right? Of course 2wd's have upper control arms [sm=icon_stickpoke.gif]
ORIGINAL: Tani1500
The post was edited after the fact [sm=icon_beat.gif]
Old Aug 17, 2006 | 03:26 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
everyones fightin over this one cuz its ramGIRL
Old Aug 17, 2006 | 04:13 PM
Tani1500's Avatar
Tani1500
ORIGINAL: fiveliterbtr
ORIGINAL: Tani1500
ok so thats my fault some how[sm=boink3.gif]
Old Aug 17, 2006 | 04:24 PM
GOD RAM IT's Avatar
GOD RAM IT
do they lean in at the top or on the bottom?
