no voltage at iac
Old Aug 26, 2006 | 01:55 AM
shott8283's Avatar
shott8283
Default RE: no voltage at iac
thats odd... disconnect your batt (neg cable) and pull the cannon plug that the iac wire/wires goes into and make sure theres no corrosion or bent pins... also.. shoot continuity from the respective pin/pins to the base of the wires..making sure there isnt a break in the plg its self .. trying to rule out all possiblities.. i think if you took the truck to the stealer (god forbid) they might be able to scan the computer for circuit faults.. also .. it may be worth while to change the iac,,, maybe the internal circuitry isnt connecting the circuits and giving false readings or data to the pcm. but thats kinda shootin in the dark
Old Feb 18, 2018 | 11:12 AM
Rg1979's Avatar
Rg1979
Originally Posted by 01sportram
I tested for voltage because the truck has a rough idle. The pintle on the IAC would not move so I bought a new one and that didnt help the idle problem. The Haynes manual said to check for voltage between the purple/black wire + and the brown/white wire - . Since there is no voltage I figured the pcm was bad. The computer has not thrown any codes but the IAC is not working , will not adjust idle when AC is on etc.
Im having the same problem with my 00 ram 5.9. I get no battery (12.0 or higher) voltage on the purple/white connection but at times I do get battery voltage. How did u fixed your truck?
Old Feb 18, 2018 | 12:15 PM
12 year old thread.......
You should see 12 volts on two wires in the iac connector, with the ignition on. (engine not running) If you don't, verify the wires are good, if they are, replace the PCM.
Old Apr 14, 2018 | 06:37 PM
Rg1979's Avatar
Rg1979
Default 00 ram 5.9 iac valve problems
Hi everyone Im a newbie and love the site. I have a problem with the IAC , it does not show any voltage. Do I need to get a new pcm ?
Did u ever fixed your truck? If u did what solved it?
Old Apr 14, 2018 | 09:28 PM
Why don't you just start a thread with your problem, and see if we can help you. I don't think anyone that posted in this thread, aside from you and I, are even still around any more.
