no voltage at iac
Old Aug 24, 2006 | 11:01 PM
01sportram's Avatar
01sportram
Default no voltage at iac
Hi everyone Im a newbie and love the site. I have a problem with the IAC , it does not show any voltage. Do I need to get a new pcm ?
Old Aug 25, 2006 | 02:12 AM
silverram99's Avatar
silverram99
Default RE: no voltage at iac
Chase your wiring and check all your fuses before you go to the expense of a new PCM. I know it is time consuming but its worth the money you could save for a 50 cent fuse or wire connector. If you don't already have on go get a test light, 20 bucks at sears.
Old Aug 25, 2006 | 11:57 AM
01sportram's Avatar
01sportram
I traced the wires from the pcm to the IAC and it showed continuity . What fuses should I check. Thanks for the reply .
Old Aug 25, 2006 | 03:03 PM
silverram99
I would just check all of your fuses, without studying a wiring diagram I don't know for sure which one controls that function. If nothing else you might find a fuse that you didn't know was blown. It's just not a bad idea to be sure before you drop the big money on a computer then you have to take it to the dealership to have it flashed.
Old Aug 25, 2006 | 09:25 PM
01sportram's Avatar
01sportram
I checked all the fuses , all were ok. When I probe the purple/black wire + and the brown/white wire - there is no voltage but if I put the negative lead from the voltmeter to a ground I get 12 volts + . Should the voltage be that high ?
Old Aug 25, 2006 | 09:48 PM
TMS Bill's Avatar
TMS Bill
Are we talking about the Idle Air Control Motor here?
Old Aug 26, 2006 | 12:12 AM
01sportram's Avatar
01sportram
Im talking about the wires going to the idle air control motor.
Old Aug 26, 2006 | 12:59 AM
TMS Bill's Avatar
TMS Bill
According to the FSM (2001 yes?), there's 4 wires used in that circuit. 2+ and 2- ... it's a "stepper motor" ... it doesn't run ... it positions. The 4 colors are Gray/Red, Yellow/Black, Brown/White and Purple/Black. The PCM pulses the "motor" to various positions based on, among other things, engine coolant temperature and intake air temperature. You may not have a PCM or IAC problem. Garbage In - Garbage Out ... If one of the sensors is bad ...
Oh ... you don't show any voltage across those two wires for one of two reasons ... they either both have +12 on them (voltage is a DIFFERENCE in potential) or one has +12 and the other is open (because the PCM wants it that way). You have to read voltage from each wire to ground and the fact that a wire doesn't have a voltage on it at any given time in a digital circuit is meaningless.
What made you check voltage? What are your symptoms? Truck won't run?
Old Aug 26, 2006 | 01:40 AM
shott8283's Avatar
shott8283
make sure the 2 12V wires have 12V to ground, and the 2 12V neg wires have contiunuity to ground or atleast continuity between teh farthest ends of eachother...
Old Aug 26, 2006 | 01:51 AM
01sportram's Avatar
01sportram
I tested for voltage because the truck has a rough idle. The pintle on the IAC would not move so I bought a new one and that didnt help the idle problem. The Haynes manual said to check for voltage between the purple/black wire + and the brown/white wire - . Since there is no voltage I figured the pcm was bad. The computer has not thrown any codes but the IAC is not working , will not adjust idle when AC is on etc.
