starting problems
Old Aug 26, 2006 | 10:11 PM
TMS Bill's Avatar
TMS Bill
Default RE: starting problems
Brother, all I can tell you is that, solenoids, being active components, are supposed to make noise. Humidity rarely effects low voltage components. It never effects NO voltage (vacuum) components. I don't have a service manual open in front of me so I don't have any idea of the item that you're talking about (race is on). A picture would help like you would not BELIEVE! [8D]
Where are you at that the humidity is killing your ride? I used to be on Cape Cod so I've seen all this before.
Old Aug 26, 2006 | 11:51 PM
lb1995ram's Avatar
lb1995ram
Here is the pic of the main thing!!! i tried to get the best pic and if u want different ones i can get them... i live in Mackinaw City michigan and today is the only time i could not get it started [:@] i am getting really poed at my truck at this moment.. its the thing on the upper right corner w/ 4 things sticking out
[IMG]local://upfiles/37477/3C40BEC8BE2E4EC0B5779F34B55A40D4.jpg[/IMG]
Old Aug 27, 2006 | 12:39 AM
TMS Bill's Avatar
TMS Bill
Ok ... I don't have a '95 manual but the closest thing I can come to that looks like what you have pictured (in my '98 manual) is a Duty Cycle Evap Canister Purge Solenoid which has nothing to do with starting the truck. It regulates the rate of vapor flow from the EVAP canister (under PCM control) to the throttle body.
You can try capping off all the lines and ports from and to this and see what happens but I doubt if you'll see any difference.
The only other thing I can think of (besides what's already been mentioned) is carburator icing (happens under cool - high humidity conditions) but these trucks are fuel injected so that's crap.
Lemme think some more ...
Old Aug 27, 2006 | 12:46 AM
lb1995ram's Avatar
lb1995ram
okay thanks...
