Newbie Here and with a question
Old Aug 28, 2006 | 05:00 PM
Mayfair's Avatar
Mayfair
Default RE: Newbie Here and with a question
ORIGINAL: The Burning Rom
[ Like I mentioned up there ^^^^, it's important that you put it into 4wd every month to keep everything lubed and to keep the vacuum parts soft and working correctly. Most people don't know that, and as a result, when you buy a used Ram it hasn't been maintained properly in that aspect. I could tell mine hadn't when I got it. At first it was very hard to get it into and out of 4wd, but it's almost instant now...to get into 4H anyway. Getting out usually requires a backup, or traveling at least 50ft forward to get it to jump back out.
I'll be honest with you, I never knew that and I've never done it, but I'll start today. Thanks !!
How far do I have to drive in 4wd for this maintenance? Also, I usually only shift into and out of 4wd either in park or in drive at a dead stop just out of habbit. Is this fine, or do I have to be rolling, then shift into neutral while on the roll before I shift into 4wd?
Thanks again !!
Old Aug 28, 2006 | 07:52 PM
TMS Bill's Avatar
TMS Bill
quote:
ORIGINAL: TMS Bill
My 4WD light stays on for a while after I disengage 4H. Most of the time I have to drive for quite some time (up to a hundred yards or so) before it decides to shut off.
Has your's EVER shut off?
When the 4WD light is on, that means your truck is still in 4H
Sorry ... I should have been more precise. When I input a command for 2H (with the selector), most of the time the truck requires some distance to respond as well as a bit of left/right steering and on/off the gas (sometimes). [8D]
