Surging Idle
Old Aug 27, 2006 | 05:19 PM
BlueBeast2's Avatar
BlueBeast2
Default Surging Idle
My truck has this werid surging idle issue. It seems to be doing it a lot more lately when I start it up. It will go up to like 2 grand then drop down and surg back up and will keep doing it. Sometimes hitting the gas calms it down a little. Any idea on what would cause this?
Old Aug 27, 2006 | 09:02 PM
steve05ram360's Avatar
steve05ram360
Default RE: Surging Idle
your IAC is most likely on it's way out. it's supposed to control the idle speed and if the motor is not responding, it'll idle funny.
Old Aug 28, 2006 | 12:14 AM
20dodgeram01's Avatar
20dodgeram01
is this on start up or all the time??
Old Aug 28, 2006 | 01:35 AM
BlueBeast2's Avatar
BlueBeast2
it does it sometimes a while after start up its not just at startup if that makes any sense
Old Aug 28, 2006 | 02:31 AM
steve05ram360
yeah it does... your IAC valve is going bad. it's on the back of the throttle body. swap it out and you should be good to go.
Old Aug 28, 2006 | 03:56 AM
BlueBeast2's Avatar
BlueBeast2
whats one of them suckers run?
Old Sep 3, 2006 | 03:29 PM
1RewdRam's Avatar
1RewdRam
Probably is the IAC but ................... has anyone been working topside under the hood recently? If the air filter housing isn't seated and clamped properly to the TB air will enter at that joint and cause the same symptoms. Had the same problem, FIXED.
Old Sep 3, 2006 | 03:56 PM
BlueBeast2's Avatar
BlueBeast2
umm not for a while but I will check it out. I found on advance's site and IAC is like 50 bucks not bad I guess. How hard is it to change out? And does it hurt anything having a bad one?
Old Sep 3, 2006 | 05:25 PM
1RewdRam's Avatar
1RewdRam
ORIGINAL: BlueBeast2
Don't want to offend here but I wouldn't buy anything $$ at Advance. Went through 4 rebuilt carbs before getting one that lasted, 3 wheel bearing assemblies on my s-10 blazer, 2 sensors on my old s-10 PU. Batteries were a good value tho. If it's out on the shelves np, but anything else think twice. It's less expensive for a reason. Hurt? Why don't ALL vehicles rev at idle?
Old Sep 3, 2006 | 05:44 PM
BlueBeast2's Avatar
BlueBeast2
I have been buying stuff at advance for a long time and never had any problems. So I guess that means I should change it
