I have a question, so I came to the experts
Old Aug 30, 2006 | 07:34 PM
SFC Hall's Avatar
SFC Hall
Default I have a question, so I came to the experts
I just bought a 98 1500 4x4 with the 318. I have had a Dakota for the past 13 years and loved it. Anyway my neighbor had this 1500 for sale and I bought it…
Now, I am noticing that the steering seems very loose, 3 or 4 inches of play in the steering wheel. Is this normal? The truck has 70,000 miles and has not been abused; the worst off road it has ever seen would be no more than a well kept dirt road. I love everything else, it is in near perfect condition… just the steering, can I tighten it any way (have it done)…
Any comments of advice would be greatly appreciated. thanks
Old Aug 30, 2006 | 09:57 PM
cattleman40's Avatar
cattleman40
Default RE: I have a question, so I came to the experts
Sarge, check your wheel bearings they might be loose. If that is not the case check suspension or steering components(ie, tie rods, pitman arm, and steering damper). Lastly check the steering gear box and make sure it is not damaged or out of adjustment.
Old Aug 30, 2006 | 11:18 PM
Ram1500Dodge's Avatar
Ram1500Dodge
just sit inside the truck and tell it that you will get rid of it if the problems dont fix themselves, thats what i do and the problems usually go away...j/k i agreed with dude above me
Old Aug 31, 2006 | 01:42 AM
The Burning Rom's Avatar
The Burning Rom
Trac bar! If it's never been replaced, then it's time
You should have someone lay under the front end. Then turn the key on to unlock the steering wheel and JUST wiggle it back and forth. To the point where the wheels barely start to move. The person underneath the truck should be able to see where the play is.
Old Aug 31, 2006 | 02:04 AM
dibblejr's Avatar
dibblejr
Off the topic. I am also a SFC in the Army stationed at Fort Drum and have just purchased my 98 Ram 1500 sport in the black and red trim.
Old Aug 31, 2006 | 12:47 PM
SFC Hall's Avatar
SFC Hall
what unit? I am in Aviation Career Counselor...
and thanks guys, I did a search on here and found a lot of information. I will try the Dodge fix first http://dodgeram.info/tsb/1997/19-10-97.htm ... then look at some of the after market products...
