Big Red Tonka Pictures-- here they are
#23
RE: Big Red Tonka Pictures-- here they are
There is one bad thing about dodge's and big tires--- the turing radius of the front axle with larg tires is limited because dodge as a tall but narrow wheel well...This means that big tires might fit but serioius problem will occur when turning!!!!.....I could clear 44's with this set up, but that only moves tires 2 inches into the wheel well, not taking up much space..
There is something missing...If you look close at the top of the coil over fabtech springs, there is custom support bracket. On that bracket is a couple of shock mounts which will serve to hold a stainless RAM cut out (like a license plate) but RAM has been cut out of it...It is backlit in red l.e.d's and helps to fill the well....If you look close between the rear shock set up you will see s hitch light with the RAMS head on it that was fabed into the bracket for the dual rear shocks.......
#24
its awesome...great job..it just needs much bigger meat on the rims to fill in the openess and maybe push them out some so it doesnt feel like tis going to flip over at every turnj of the steering wheel..im sure your center of gravity probably makes it pretty hairy to drive around corners but that jsut comes with going that extreme..I give it 2 thumbs up!!..good job
#26
This truck will perform as well, just to let you know, but this was with the stock axles detroit locker and 4:56'S
[IMG]local://upfiles/43051/7AA8D801E29242AEABBA24B3065684AC.jpg[/IMG]
[IMG]local://upfiles/43051/1C494E3C402942FBA5025A92A78DC97C.jpg[/IMG]
#27
#28
Here is some more of the pre swapped ford axles on 39.5 boggers......
Some are from the top of "test hill" at the silver lake sand dunes in Michigan.....
And the beautiful lady I included is my wife--- who lets me do all the bad little hobbies
[IMG]local://upfiles/43051/5D6085A45C3446A68AA61DB128889EBA.jpg[/IMG]
[IMG]local://upfiles/43051/34023785355540A49E3A9ED7F6F0541A.jpg[/IMG]
[IMG]local://upfiles/43051/15FE1ED5BF094AA0BBDAD6A0EA6F244F.jpg[/IMG]
[IMG]local://upfiles/43051/F850E48A517748C8BBF2CF8C0F7659AC.jpg[/IMG]
[IMG]local://upfiles/43051/28A81105512945B7836F5A4AD58BBFE4.jpg[/IMG]
