This can't be good....
Old Sep 1, 2006 | 06:53 PM
miknwv's Avatar
miknwv
Default RE: This can't be good....
I have no clue, but would love to find out. One guy who rebuilds engines said I could possibly have a carbon buildup causing it.... Does that sound likely?
Old Sep 1, 2006 | 07:51 PM
bamory's Avatar
bamory
I can remember last winter I changed my oil it was like 20 outside, I didnt heat oil (take it in house) before i put it in so it was kinda thick, when i fired motor up it knocked so bad, scared the **** out of me. Last time I do that.........lol
That is a good question, who does sell a good replacement motor at a good price?
Old Sep 1, 2006 | 08:06 PM
miknwv's Avatar
miknwv
Actually I talked to my buddy, we're gonna rebuild it. I'm gonna go ahead and throw some performance parts in there while I got it apart. Any ideas?
EDIT: Ok, those of you who know me know that I can't open a hood without f***ing it up....my buddy's doin it, I"ll be his gopher. LOL
Old Sep 2, 2006 | 12:17 AM
05SilverHemi's Avatar
05SilverHemi
I just went through this same thing with my motor. 106k and it was junk! Blowing smoke and loosing oil pressure while driving.
First I priced a rebuild kit for it. Cheapest I found one was for $975. Thats some serious money for a rebuild kit!!! Definately a far cry from a small block chevy rebuild kit.
Some other option are a crate motor which will run you around $1500. In my personal opinion if you are dead set on a new motor, get the crate motor. By the time you get the rebuild kit and have the machine work done to oversize the pistions your right at the cost of a crate motor. This is also the fastest way to get the truck on the road again.
If you dont need pistons/rings then you can get a crank with bearings for $225. You can get a set of stock size rings for around $110. Even after you do this, you still have your heads to deal with, gaskets, etc.
I searched online at www.car-parts.com and found a low mileage 360 out of a 97 Ram. Turns out it was at a yard a buddy works at. I got the motor with 61k original miles for $650. Put it in and it runs mint.
There are many options. Just depends which road you want to go down to get it on the road again. I did the salvage motor so I can tear down my stock motor, build it up and put it back in later.
Old Sep 2, 2006 | 12:23 AM
miknwv's Avatar
miknwv
We're gonna pull the motor and put a new crankshaft in. My brother in law listened to it a bit ago and he just looked at me and said "yea, its f***ed." While I"m at it I'm gonna put an oversize cam in it. Any suggestions on that? Plus, does anybody have a chilton manual they wanna sell for cheap?
Old Sep 2, 2006 | 12:47 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Read the "Merry Christmas" thread. You can download the Field Service Manual there. Chock full of more information than a person ought to have.
ORIGINAL: 360sport
Rebuild kits -- You get what you pay for.
Used engine -- You get what you pay for.
IMHO, do the job right the first time. I honestly thing you lucked out with dropping a used engine from a junked vehicle into your truck. I am the kind who will spend the money to go through everything from the get go. Imagine how you would feel dropping in a $650 used engine and having it fail within a few weeks or months.
Gary-L's Avatar
Gary-L
Veteran: Navy
Old Sep 2, 2006 | 03:50 PM
miknwv's Avatar
miknwv
Yea, I'm gonna take the time to rebuild it right, one of my buddies is gonna help me. I'm gonna sink about $600-700 into a new crankshaft, oversize cam, etc
Old Sep 2, 2006 | 05:13 PM
05SilverHemi
ORIGINAL: VWandDodge
ORIGINAL: 360sport
I knew I did not luck out. The truck was wrecked and came in running. We compression tested the cylinders and did a leak down. All checked out very good, then ran it through the rpm range. For $650 I could not go wrong. You cant get a new motor for anything close to that. Everyone has their own way of getting an end result.
For what this truck is used for, I had no second thoughts. For someone who is using their truck as a daily driver then it is a different story.
Old Sep 2, 2006 | 08:06 PM
miknwv's Avatar
miknwv
If I do decide to put an oversize cam in it, what exactly do i need to buy/do to the truck?
