This can't be good....
Old Sep 1, 2006 | 03:25 PM
miknwv's Avatar
miknwv
Default This can't be good....
Heard a knocking/rattling noise on light throttling at around 3000 rpms in my motor...took it to my mechanic, he listened to it and said its the crankshaft and bearings. does that sound about right?
Old Sep 1, 2006 | 03:29 PM
silverram99's Avatar
silverram99
Default RE: This can't be good....
A knock is sort of hard to just generalize like that. Depending on the exact sound of it, it is very possible that it is the crank. Could be other things though also. How many miles does the motor have on it?
Old Sep 1, 2006 | 03:33 PM
miknwv's Avatar
miknwv
Motor has about 104,000 miles on it. The mechanic is pretty good, but wont touch a crankshaft....he hates dealin with it, lol. It sounds kinda like a rattling/pecking...it does it between 2000 and 3500 RPMs, loudest at 3000. You can hear it best when you give it light throttle at high RPMs...if you hammer down on it, you can barely hear it.
Don't know if this is related, but my oil pressure has been acting funny lately. It stays right below 40 and won't move with acceleration. Yesterday I pulled up to a stoplight and the oil pressure bottomed out at 0. I shut it down and restarted it and the pressure went back to right below 40. I checked the oil, it was only 1-1/2 quarts low, so i added a quart...still didnt change the sound any or the oil pressure.
Old Sep 1, 2006 | 03:51 PM
silverram99
ORIGINAL: miknwv
Yikes! 1 1/2 Quarts low? That is a considerable amount on an engine that only holds 5. Anyways, it kinda sounds like your mechanic is probably right. It's hard on an engine to be run with out the right amount of oil in it and that could cause bearing failure. I would see if you could find a mechanic interested (or do it yourself) in dropping the oil pan and taking a look at the bearings. If you wanted to be exact on your oil pressure you might hook up a manual gauge, but if your bearings are shot thats not gonna do much good anyway. Good Luck!
Old Sep 1, 2006 | 04:01 PM
miknwv's Avatar
miknwv
Yeah...I just got off the phone with several people, they've told me I'm better off buying a used factory motor and just replacing it. Any thoughts on where I can get a cheap one or what to look for, etc?
Old Sep 1, 2006 | 04:17 PM
silverram99
It just depends, are looking to stay stock with the motor or upgrade a little? There is probably a good engine rebuilder in your area if you are looking to stay stock. A crate motor is another option. I personally would rebuild it myself if my truck did that. So how much do you want to spend and what are you planning to do with your truck?
Old Sep 1, 2006 | 04:36 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Rebuild it. I am in the process of rebuilding my engine and I'm upgrading many items (brass core plugs, aluminum water pump, hi-flow oil pump) and I was able to stay standard. I am reusing the rods, pistons, cam, and crank. I did some porting and polishing on the heads (not the greatest, but better than nothing) and I'm going to be doing the intake mods. I bet my total outlay is less than the $1,300 I have thus far paid the builder. I am going to install a higher output alternator and a new radiator. You can check out the thread about my engine in my sigline.
Old Sep 1, 2006 | 04:38 PM
Dodge4x4810's Avatar
Dodge4x4810
If your losing oil and it is knocking/pinging. Check yout plenum gasket, if your not familiar with this its the pan at the bottom of the intake manifold and it is known to go bad on these generations, it happened to me. Take the air intake off and look down throught the butterflies in the throttlebody and see if you see and oil in the bottom of the intake, if you do the plenum gasket is blown, if it is blown do not wait too long to fix it. This problem caused a burnt valve for me, and after you fix it i would run a cleaner thought the engine to get the oil out, like Sea Foam.
Good Luck
Old Sep 1, 2006 | 04:46 PM
miknwv's Avatar
miknwv
I just had the plenum replaced a month and a half ago. I've heard the motor ping with the "spark knock" and it's a totally different sound. This noise is directly proportional to teh amount of RPMs I'm running.
Old Sep 1, 2006 | 06:11 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I forgot to mention that I wonder if you either have a rod knocking or you have spun a bearing. I had a similar issue present itself on a 4.3L Chevy Blazer, where rod #4 snapped and *WHUMP* shut down the engine. It was not a pretty sight.
