rear brake shoe questions
Old Sep 4, 2006 | 02:23 PM
waynerds74's Avatar
waynerds74
Default rear brake shoe questions
I'm trying to replace my shoes and i cant get the drum off...question is...do i rotate the adjuster up or down to loosen the shoes? any help would be great...thanks
Old Sep 4, 2006 | 02:49 PM
shepard's Avatar
shepard
Default RE: rear brake shoe questions
As you look through the inspection hole, I believe you should be turning the adjuster up, but you would want to insert another screwdriver on the top of the adjuster to push the adjusting lever outward to realease the star wheel, otherwise you'll be fighting that darn thing. That's the way I do it, and it spins easily.
Old Sep 4, 2006 | 02:53 PM
shott8283's Avatar
shott8283
when you get the adjuster dialed down... put the rearend up on jack stands..tires off... start the truck and put it in drive... for some reason the drum works itself off... if it doesnt apply the brakes a little and the shoes rubbing against the drum work themselves off.. pretty neat trick... just ogtta be REALLY CAREFULL!!! for obvious reasons...sure beats wacking it with a sledge.... again i gotta say do it carefully and chock the front wheels too
Old Sep 4, 2006 | 03:05 PM
TMS Bill's Avatar
TMS Bill
You forgot the part about leaving a lug or two threaded partway on ... or do you LIKE chasing your drums down the street?
Oh, that's right ... you like EVERYTHING about drums.
Old Sep 4, 2006 | 03:08 PM
shott8283's Avatar
shott8283
LMAO!!!
c'mon bill,,, you spoiled the surprise!!!!
yea.. i love me some drums now,, only if they melted down and made into some new rotors for me
