clutch again
Old Sep 5, 2006 | 01:09 AM
BIGSEXY's Avatar
BIGSEXY
Default clutch again
I put a clutch in about 6mo ago.The clutch was good but the throwout bearing was bad,I replaced everything.The new throw out made little noises since the day I put it in,Nothing crazy but a little noise now and then.NOW when I start the truck in gear the clutch grabs even pushed in then it will be allright.Could this be the slave cylinder or master.Really gettin pissed off.And NO its not my driving Ive been driving trucks all my life.I think its these Fu@*%&^ chineese parts.[:@][sm=dontgetit.gif]
Old Sep 5, 2006 | 04:53 PM
DieselDemon's Avatar
DieselDemon
Default RE: clutch again
Did you know that 50% of the chinese population has Cataracts ?!?!?!?!?!?!?!
The other 50% drive Rinkins......................
Old Sep 5, 2006 | 09:04 PM
TMS Bill's Avatar
TMS Bill
My truck doesn't have a stick so this is all I've got ... from the FSM:
Clutch will not disengage properly.
1. Low clutch fluid level. 1. Replace hydraulic linkage assembly.
2. Clutch cover loose. 2. Follow proper bolt tightening procedure.
3. Clutch disc bent or distorted. 3. Replace clutch disc.
4. Clutch cover diaphragm spring bent or warped. 4. Replace clutch cover.
5. Clutch disc installed backwards. 5. Remove and install clutch disc correctly.
6. Release fork bent or fork pivot loose or damaged. 6. Replace fork or pivot as necessary.
7. Clutch master or slave cylinder failure. 7. Replace hydraulic linkage assembly.
Hope it helps.
Old Sep 8, 2006 | 12:22 AM
BIGSEXY's Avatar
BIGSEXY
Think I narrowed it down to the hydraulics.........we"ll see.Thanx
