how to clean throttle body
Old Sep 5, 2006 | 02:56 PM
Big_N_Bad's Avatar
Big_N_Bad
Default how to clean throttle body
How do you clean the throttle body and what do you use. Do you recommened getting new gasket too.
Old Sep 5, 2006 | 03:16 PM
silverram99's Avatar
silverram99
Default RE: how to clean throttle body
To clean it the right way you need to remove it, so yes you will have to get a new gasket. When I did mine I pulled it off and took out the sensors and the IAC. Then I put it in the carbereutor cleaner barrel for about an hour. If you dont have access to that then you can just spray it down really well with carb cleaner. You should also carefully clean up the IAC and then put it all back together and re-install it.
