Tapping in for Fuel PSI
Old Sep 11, 2006 | 06:53 PM
Brad426's Avatar
Brad426
Default Tapping in for Fuel PSI
Any suggestions for and how to tap into the fuel system for a fuel pressure sender unit (Autometer). I think it is 1/8" pipe. is there enough meat (metal) on the end of the fuel rail? Whould a "T" in line be the best way? Thanks
Old Sep 11, 2006 | 07:32 PM
steve05ram360's Avatar
steve05ram360
Default RE: Tapping in for Fuel PSI
you could cut the cross over and tap in there, I believe it's a thick rubber hose, just add the right size t and you should be set. make sure you use fuel injection lines... normal fuel lines are not strong enough.
