Transmission Problems/ Rebuild
Old Sep 11, 2006 | 11:43 PM
Sehr916's Avatar
Sehr916
Default Transmission Problems/ Rebuild
Hi. Although I am not sure what exactly my problem is I know that my transmission needs to be rebuilt or at least worked on. How difficult is it to rebuild yourself? What special tools are needed? How can I find out if my problems are torque converter related or some other part of the transmission? How are kits like this for quality? Transmission Rebuild Kit I was thinking of maybe taking the truck into a tranny shop and having them check it out and then maybe doing it myself. How much does a good tranny check go for? Thanks a lot for the help.
Old Sep 12, 2006 | 04:06 AM
silverram99's Avatar
silverram99
Default RE: Transmission Problems/ Rebuild
Everyone can say what they want about me but I wouldn't attempt to rebuild an automatic tranny on my own. I guess they make those videos to walk you through the process but still that sort of scares me. One of my exams for school is to rebuild a tranny and let me tell you I am not looking forward to it. On the other hand I have to say that I have seen people rebuild transmissions and have them work out just fine so I guess it depends on how much skill and confidence you have, also you have to keep in mind if its not right the first time YOU get to pull it out and fix any mistakes you made, atleast with a good tranny shop its on them and not you.
Old Sep 12, 2006 | 10:27 AM
alcedo's Avatar
alcedo
Save yourself the frustration. Do some research, find a good trans shop (not a chain but one that is privatly owned) tell them to build you a tranny that will last, get a warranty, give them 2K $ and be done with it.
Old Sep 12, 2006 | 04:13 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
If you're compentent with tools, can rebuild it in a clean environment, and have patience, I vote to DIY. I plan on rebuilding my truck's transmission next spring. I am already doing the engine, and this is my first engine build. The #1 rules for transmissions is to oil everything, and then oil it again. Keep everything clean, free of contaminant, and then oiled.
I hate most all transmission shops, because they have people baffled into thinking there is some special type of voodoo needed to work on a transmission. If you can read and exploded parts diagram, then there should be no problems.
Old Sep 13, 2006 | 12:18 AM
miknwv's Avatar
miknwv
SEHR what is your transmission doing? There are problems transmissions have that are caused by sensors and not the transmission itself. Do the RPMs slip a bit while driving down the road? May be due to a throttle position sensor.
Old Sep 13, 2006 | 12:51 AM
Sehr916's Avatar
Sehr916
I don't want to take the time to describe just trust me on this one.
If transmission kits are fairly inexpensive why is it so expensive to get one rebuilt? When you get a tranny rebuilt at a shop what all do they usually replace?
Thanks
Old Sep 13, 2006 | 12:54 AM
DieselDemon's Avatar
DieselDemon
I have a 95' 2500, CTD. I have to be honest with ya. I try to do all my work on my own. So far, I have come across 2 things that I am not at all comfortable doing. My axle seals, and my tranny. 2 months ago I had the ATS 5 Star tc installed, and the tranny rebuilt with ATS shafts, and clutches, etc. The transmission guy let me watch the whole process. I hope you have a lift, some tranny/t-case jacks, and some costly specialty tools. The amount of parts that came out of that case were incredible. The pump, the clutches, the planetaries, the valve body, seals, etc. I know auto trannys have been around for a while but the physical mechanics of it all still amazes me.
The tranny tech did quite a bit of measuring tolerances, clearances, etc. He dialed quite a few parts. You look at this big tranny, and then see tiny little seals that stop fluid from leaking to the outside. It is amazing, for sure.
I've done my transfer case with a buddy, and that wasn't too bad. We were able to rent the tools from a local shop for the weekend. Even if you did the tranny yourself, there are pressure adjustments that need to be done. My shop has a dyno for checking all that stuff.
You're a brave man to tackle that job yourself.
MUCH good luck to ya. If you diy, please take pics and keep us all up to date, please.
I like Alcedo's suggestion. Let someone else do it. I would consider beefing up anything you can while remaining within a budget. I was charged a flat $900.00 for all the labor. Even these days that's a lot of money. It took the guy three days to remove, disassemble, clean, and rebuild. The last thing you want is a guy who tells ya he can do it in a day. It's impossible unless 5 guys are working on it at once.....lol
Just my opinion.
Take care.
Old Sep 13, 2006 | 01:09 AM
TMS Bill's Avatar
TMS Bill
ORIGINAL: Sehr916
Thanks
Reletively labor intensive ... this related to your using park to stop your truck? Reverse gone?
How bad do you need your truck to be up and running? That would probably be the main factor that would decide it for me. If the answer is "now" ... take it to a shop.
Old Sep 13, 2006 | 12:21 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: DieselDemon
Just my opinion.
Take care.
Your opinion is valid and your argument is well represented. Now, consider this -- Why do transmission shops *insist* on scaring people into thinking transmission are so mysterious, cryptic, and taboo to touch? If transmission shops are so good at what they do, why is it that sometimes a vehicle owner will have to take the car back two, three, or even five times to get the damned thing fixed properly? How come none can ever give a ball park figure for the "average" repair? At one time I called around for quotes on getting a 1989 700R4 transmission rebuilt and received quotes anywhere from $1,100 up to $2,850!!! I found a DIY video that stated with parts and tools I could tackle the job myself on a Saturday afternoon all for under $900. Of course, like an engine, the better quality parts you install into the transmission the higher the rebuild cost, but then again, you get what you pay for.
I know a fellow whose father is a training mechanic for a race car team. His partner is the Dodge mechanic, and they told me that the Dodge transmission is very easy to fix if I take my time and get a rebuild kit as well as having a clean work area. That's why I advocate to the DIY people that if you can afford to have your truck down for a while and you can read a manual, then learn something.
Old May 21, 2007 | 09:13 PM
bigred1977's Avatar
bigred1977
I was going to reuild my tranny but after looking at all the special tools needed I decided to go with a reman. It is incredibly complicated to do a transmission rebuild.You could do it in your garage but your looking at the cost of a lot of toolsyou would only use once. I found a reman at autozone for about 1300 ucks with a 3 year warranty
