1500 towing
Old Sep 13, 2006 | 11:03 PM
rmmoore's Avatar
rmmoore
Default 1500 towing
My son has an '01 1500 with the towing package & 5.9 engine. He's thinking of buying a 24', 5000 lb. 5th wheeler. Is this too much trailer for the truck, or is it reasonable for him to tow this?
Thanks,
Roger
Old Sep 13, 2006 | 11:14 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: 1500 towing
The trailer wouldn't be too much for the truck with the proper hitch and a brake controller, BUT does he actually want to put something on the trailer? If so, then he would be pushing it big time with only a 1/2 ton.
Old Sep 13, 2006 | 11:42 PM
BlueRam01's Avatar
BlueRam01
Roger,
I assume he got a camper. The truck probably has 3.55 gears, too. It might do OK if the pin weight is not too much but that is very difficult to manage woth a 5th wheel. It usually runs about 20% of the total trailer weight and that will quickly put the 1/2 rear axle over the weight limit. Will it bust the truck? Probably not, but towing it will get old. If there are a lot of hills its no fun either. Gas milage usually tanks at 8-10 mpg.
For local camping, just have fun. BTDT. Pulling with a CTD is way more fun and less stressful but everyone can't run out to buy a different truck. If he keeps the junk out of the trailer and the weight low as possible, it should work out.
SteveB
01.5 3500 ETH/DEE
96 1500 4X4 5.2
Old Sep 13, 2006 | 11:53 PM
rmmoore's Avatar
rmmoore
Thanks--I should have mentioned it's a camper, so just the typical camping gear would be in it.
Old Sep 13, 2006 | 11:57 PM
rmmoore's Avatar
rmmoore
Thanks for the information, Steve. I don't think he'll be towing it far, but there are a few hills in northern Michigan, where he lives. Sounds like he'll have to be careful & realize it's a heavy load for the half ton.
Roger
Old Sep 14, 2006 | 12:15 AM
Socha_62's Avatar
Socha_62
Northern Michigan REPRESENT
