NO DASH/MARKER LIGHTS??????
Old Sep 14, 2006 | 09:47 PM
zoomzoom's Avatar
zoomzoom
Default NO DASH/MARKER LIGHTS??????
I HAVE A 95 ram after hitting a pot hole i lost all dash and marker/tail lighhts. i replaced the headlight switch witch did nothing. if i pull the switch to just before the parking light setting the lights work but at the park light and headlight setting there is no dash and tail lights. any thoughts on this
Old Sep 14, 2006 | 10:09 PM
DieselDemon's Avatar
DieselDemon
Default RE: NO DASH/MARKER LIGHTS??????
Not much you can do but check the wiring. Check the grounds, and the feed to the switch. If you aren't blowing fuses, then I would say bad ground or loose connection. Could be a broken wire. I hava 95'CTD and the marker/overhead light wiring runs up the drivers side A-post. I think of marker lights as the 5 lamps on top of the cab. I am probably wrong.....lol. As far as the tail lights go, do you have brake lights when you depress the pedal? If not, check to see if the brake light switch is bad or may have even popped out of it's mounting location. I've replaced about 6 or 7 over the years. Do you have 1500/2500/3500 ? Gas, CTD, etc?
I have the factory manuals for the 95. I can check and maybe let you know what color the wires are, pertaining to specific circuits.
Good luck.
