towing
Old Sep 15, 2006 | 02:11 AM
dodgefamily300's Avatar
dodgefamily300
Default towing
New to the forum. I have a 01 1500 2wd pulling a 6 x10 cargo trailer should i install an external cooler or will stock setup keep it cool enough?
Old Sep 15, 2006 | 02:20 AM
dsertdog56's Avatar
dsertdog56
Default RE: towing
If you mean tranny cooler, yes! While your at it, junk the check valve on the tranny line. Many folks have them plug, creating overheated trannys.
Also if towing, run with your OD off below 60 mph. It keeps the tranny temp cooler as well.
Old Sep 15, 2006 | 02:29 AM
dodgefamily300
Default RE: towing
Thanks for the reply, yes idid mean a tranny cooler and i always drive with overdrive off around town.
Old Sep 15, 2006 | 03:30 AM
Dodgy Style's Avatar
Dodgy Style
Default RE: towing
You should get a cooler put in and make soure you get your trany serviced once a year without fail and your trany will be alright
