low heater performance!
Old Sep 17, 2006 | 09:30 PM
stussi's Avatar
stussi
Default low heater performance!
where are all of the blend air doors, and how many are there. i have a 98 1500ram, with luke warm air coming out. my dad and i checked the heating core is hot enough that you cant even touch it, and the blower motor works fine. it blows out enough air but it is only luke warm. my dad thinks there is a stuck blend door and we dont know where all of them are we only know of the one behind the glove compartment, and that one is for recirculation
Old Sep 17, 2006 | 09:41 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: low heater performance!
Sounds to me like you might have a blockage in your heater core [&:] That's just my thought on it though based on your description.
As far as the blend doors, I'm not sure about the new cab configuration...but you can find a service manual here: https://dodgeforum.com/m_340929/tm.htm that should help you find the doors.
Old Sep 18, 2006 | 02:22 PM
Ram_sport96's Avatar
Ram_sport96
is your truck running a little warmer than normal? mine just recently started doing that and it was running warm... and one of the hoses under the truck routing out of the core was stopped up...
Old Sep 18, 2006 | 03:56 PM
Tommygunz's Avatar
Tommygunz
I have similar issue, I know its warm, but not much heat actually coming out of thew dash. How difficult is the heater core to pull. I have done it on old fords and chevy's. Is it any different?
Old Sep 18, 2006 | 09:33 PM
antz_ram's Avatar
antz_ram
i kinda have the same problem but it gets hot if u step on the gas.
Old Sep 18, 2006 | 10:09 PM
20dodgeram01's Avatar
20dodgeram01
mine used to be hot.. but since the 180 stat install its just been warm.. havent really needed the heat yet besides getting up at 5 for work.. but winter gets pretty cold around here
Old Sep 19, 2006 | 09:49 PM
Gmanf's Avatar
Gmanf
I have the same problem with my 2500. I have plenty of airflow just luke warm air. I have been told that is something i will have to live with having the v-10.
Old Sep 20, 2006 | 03:37 AM
crazykidjj87's Avatar
crazykidjj87
i have the same problem...temp is normal and stays normal...but the heat is only warm...it doesnt get hot and the cab is barely a comfterable temperature by the time i get to work.
