front hub assembly/wheel bearings
Old Sep 21, 2006 | 10:40 PM
demonslayer84's Avatar
demonslayer84
Default front hub assembly/wheel bearings
Ok, here's my problem.
My truck has been sitting still for roughly six months because I didn't have the cash to fix it until just recently. The original problem was that the brakes and the rotor on the right side needed changing out. Of course, when a truck sits up for six months, it tends to accumulate problems.
My current dilemma is in dealing with the front wheel hub/bearings. I went recently to get new bearings because the whole thing is bone dry of grease; I was told that the whole assembly was a sealed unit and would need replacing, costing me upwards of $200 which, as a college student, I can't really afford.
So, here's my question: instead of buying a new one or getting one from a junkyard, is it possible to switch out the '01 hub for a '99 hub with replaceable bearings?
Old Sep 21, 2006 | 10:45 PM
radwebster's Avatar
radwebster
Default RE: front hub assembly/wheel bearings
a '99 is also a non-replaceable bearing. they are called unit bearings (bears/hubs together in one unit). napa sells them, with a lifetime warranty, for about $130 each. if you have 4 wheel ABS they will be more expensive.
edit:just saw you have a 2wd. disregard everything i said then, i have no idea on the pavement pounders
Old Sep 21, 2006 | 11:14 PM
shott8283's Avatar
shott8283
napa online doesnt list any for a 2WD.. just a 4WD..
same thing on advancedautoparts.com
autozone.com lists them as timkin bearings.. good brand.. and lists a part number but says they ARE NOT available online or in a store..
might have to check your dealer...
as for as switching them i think the spindles are the same .... and same A arms aswell.. like rad im not postive on a 2wd..
Old Sep 21, 2006 | 11:28 PM
dodgerules86's Avatar
dodgerules86
Makeitmopar.com lists stuff for front hub/wheel bearing. To the tune of $130 ($175 from dealer) for 2WD.
Good question. I can guess what the answer is, because if it was easy to do, I'm sure more people would have done it. Horray for expensive parts [:'(]
Old Sep 21, 2006 | 11:35 PM
The Burning Rom's Avatar
The Burning Rom
I remember reading somewhere that the 2wd hub has a snap ring on the back that allows for the changing of the wheel bearing, if you can locate the correct bearing replacement. I believe it still needed to be pressed out with a bearing press though. I've never worked on a 2wd truck though, or any 01 for that matter so I can't say for sure how it's setup. If you have the hub off already, maybe you could take a look?
Old Sep 21, 2006 | 11:37 PM
demonslayer84
I won't have a chance to take the hub off again until this weekend, but I'll check it out when I do.
Old Sep 21, 2006 | 11:42 PM
shott8283's Avatar
shott8283
the 01 pdf manual doesnt say anything about a snap ring or replaceable bearings..it only refers to the bearings as "hub/bearing" when it talks about removing and replacing.. it does say that the hub bearing nut can not be reused..
Old Sep 22, 2006 | 12:12 AM
The Burning Rom
ORIGINAL: shott8283
It's an "unofficial" procedure Though I know there are aftermarket companies that sell the bearings for them. I believe Timkens lists just a bearing for the 2wd trucks and not a whole hub assembly.
Old Sep 22, 2006 | 12:19 AM
demonslayer84
So basically what you're saying is that if I can find a bearing replacement and someone with a bearing press, I could probably have the bearing changed out?
Old Sep 22, 2006 | 01:04 AM
The Burning Rom
ORIGINAL: demonslayer84
If it's the kind of hub I'm thinking it is. All depends on what you find when you pull it off the truck.
